Seems slow/sluggish after tune? (w/ pics)
MisplacedCanuck
Year and Model: 2002 XC70
Post by MisplacedCanuck »
Installed a tune on my 2002 Volvo v70 xc today... And it feels essentially the same? Ive driven another, 2004 V70 XC and it feels peppier then mine, and it was stock. After consulting the almighty internet, I began to check all the charge piping connections, starting at throttle body:
Throttle body to intercooler looked good
Intercooler to charge pipe looked good
Charge pipe to turbo discharge looked good
To me, that's all the pressure piping. Lo and behold, just beyond there, a nightmare.
I've attached pictures of the air intake hose. It wasn't attached. Could this be why the car feels sluggish? Should I go back and check downstream of turbo again?
Also... Where is the famous TCV everyone keeps talking about? Is the small box I've shown in pictures it?
Thanks again!
2002 Volvo V70 XC
- Pete -
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
I’d say she’s done for. Not even worth keeping that pipe for a backup :D
Yep, that’s the TCV alright.
Snabb makes an inexpensive replacement for that turbo inlet pipe. I think they are around $140-150. Stock is probably a little less than that.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
MisplacedCanuck
Yeah, I'm trying to source a new one. Would this be why I'm having performance issues? It feels like there's barely any boost.
I thought the TCV lives on the turbo? Looks like it has maybe been relocated on this car?
2002 Volvo V70 XC
- Pete -
Post by - Pete - »
Actually, the CBV (Compressor Bypass Valve) lives on the turbo. The TCV is your Turbo Control Valve, aka, BCS or Boost Control Solenoid. Without it, you will only make as much boost psi as your wastegate is set to. It normally is clipped to the side of the airbox, underneath the pipe running from the airbox to the turbo. TCV has been talked about a bit lately it seems. Interval to replace TCV is something like 30-40k.
TCV normally can be found here
CBV you shouldn't have to worry about unless your diaphragm has torn, which you would know about if it had occurred. Replacing the CBV is not fun, very tedious (bordering on painful) work the first time you do one. Tell you what, I'd do 8hr shifts 5 days a week doing intake manifold banjo bolts vs doing CBV's :lol:
Do you have a manual boost gauge? If not, I'd highly recommend putting one in. 20 minutes roughly to install and lots of good info you can glean from it. Plus if you have a tune, you can see if you are achieving what the tuner has said you should be making. Who is your tune by/from?
Having that busted up inlet pipe is definitely not helping you make power. The parameters being monitored are likely all way off.
Here's the Snabb pipe. Probably available cheaper elsewhere, maybe ViVA, Re-Volv or Eurosport Tuning perhaps.
Here's the stocker. You could probably get just the pipe sans PTC cheaper.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
MisplacedCanuck
Manual boost gauge is ordered, should be here next week. In the mean time, I'll source a stock intake pipe. Tune is from Hilton tuning.
2002 Volvo V70 XC
Been thanked: 4071 times
Stage zero first...plugs, coils, PCV , air filter.
MisplacedCanuck
Stage zero is complete, first thing I did when I got the car! Did not notice that the intake hose on the turbo had disintegrated.
2002 Volvo V70 XC
ndphotonl
Year and Model: 2001 S80 2.4T
Has thanked: 27 times
Been thanked: 33 times
Post by ndphotonl »
That is also part of stage 0 if you ask me. The base for tuning should always be good, before adding more power.
The rip in the intake hose should cause your car to run lean (extra unmetered air). I can recommend upgrading the intake hose with a uprated silicone one. It makes quite a difference!
Also do a readout with VIDA/DICE, it might show more issues which you are not aware of.
ImageVolvo S80 2.4T OEM vs Do88 Turbo Intake Pipe by Andy Ramdin, on Flickr
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
MisplacedCanuck
Hose is replaced, she is much happier now! Was a bit of a pain getting new one on there... Hidden right in the back of engine.
2002 Volvo V70 XC
MisplacedCanuck
So, installed boost gauge as per Pete's suggestion... I'm suspecting CBV is toast. I replaced all the vac lines, she makes a solid -20inHg of vac. On acceleration, hits 4 or 5 psi and holds there, every gear. Not the best.
2002 Volvo V70 XC
