No start
Ok so I have a 2006 xc90 , v8 awd and thought I had a bad starter or solenoid problem so I have a new battery and solenoid and starter are good and when I bypass the relay, attempts to crank but doesn't actually start ,'with key on ,..also it does only click once during attempts to crank with key ,idk where to go from here ,maybe the throttle control sensor? It has given me problems already
- misha
- Has thanked: 155 times
- Been thanked: 432 times
If starter is ok,then check the grounds and b+ cable from battery to starter.
Battery terminals must be clean and tight.
If that is ok..then starter or solenoid is bad.
That click you have is pointing to one of them.
You're on the wrong forum section.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Jason73chipley
- Year and Model: 2006xc90
- Has thanked: 2 times
Oops sorry
- Has thanked: 2864 times
- Been thanked: 1332 times
No problem. Locking this so there's no confusion. The topic is now here.
- 1335 Views
Last post by maverill
- 872 Views
Last post by erikv11
- 1419 Views
Last post by Clemens
- 10 Replies
- 4440 Views
- 1446 Views
Last post by renegade343
