Rear Passenger Window
netasp
Year and Model: XC90 2004
Post by netasp »
Guys,
Yesterday i am trying to roll up my rear passenger window when I heard two loud bangs, then I hear the motor trying to roll up the window but the window doesn't come up. It will come down but won't come go up.
If i roll it up by pushing it with my hands, it will eventually come down with every pothole on the road.
what am i looking at?
2004 Volvo XC90 2.5T
Thanks
wanderdüne
Year and Model: 2004, 2006 XC90 2.5T
Has thanked: 6 times
Been thanked: 45 times
Post by wanderdüne »
Hopefully it's the sliding block clips.
Use a paint scraper or beefy putty knife or trim tool instead of your fingers to remove the door card. Insert starting at the bottom and slide until you feel a clip, then pull/pop towards you, then on to the next. More like this:
netasp
Post by netasp »
It seems there a wire which is out of whack and I dont know how is it suppose to work. It gets stuck as I roll up or down. Please check the pictures
netasp
Post by netasp »
I think I might need a new regulator, are there any instructions on how to install it for XC90? There are some rivets that holds it in place, and some video suggesting that I have to drill them out and use a special machine to insert them back?
can someone confirm please?
wanderdüne
Enter the search term "download vida image". You can download the Volvo (VIDA) software that contains all the repair and replacement procedures, parts catalog etc. Pair that with a cloned DiCE unit off ebay or wherever if you want to perform diagnostics.
Yes, you would need a rivet gun and rivets and a drill motor and bit to drill it out.
This is probably similar:
netasp
Post by netasp »
Thank you. I will have to do something about the rivets gun.
I am posting some pictures from VIDA in case someone else might need to do the same thing with part numbers
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Instead of rivets, I drilled out the holes slightly and used short bolts with nuts. This worked fine and makes disassembly easier if you have to ever remove. Just make sure the ends of the bolts don't interfere with anything. I used SAE 1/4 inch bolts maybe 1/2 inch long. I believe I placed the nuts on the side you can see.
netasp
Post by netasp »
Yes. I was thinking of the same thing. For now I used twist tie and taps to wrap the handle to prevent the window from coming down while driving.
Not ready to give up the xc90 yet, 230KM on it and still going like a tank
