headliner fabric recommendation?
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
Erik, what did you use for fabric?
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
erikv11 wrote: 17 May 2020, 11:57 From the reading I did, the 3M Super 77 seems to hold out better in the heat than the 3M headliner adhesive. So that's what I used. Only been six months though, so no longevity report yet.
I redid the headliner in my old '96GLT about 4 years ago and I used the 3M headliner adhesive,850oldschool wrote: 17 May 2020, 09:52 Chuck, that's a very impressive job you did of lining up the pattern! How long since you did it? Is it holding up? Did you figure out some clever way to lift up the fabric to fine tune the positioning?
Good point about using 3M headliner adhesive. Temperatures are really high up near the roof, especially for a dark colored car.
I transferred that headliner to my '97 T5, and even with maneuvering it in and out of 2 sedans, it's still sticking fine.
The new headliner in the wife's car is only about two months old. There really was no "repositioning" once we put the two together. I was hoping for a bit straighter, but we got what we got. It took both of us to install it, as it was just a flannel/fleece type of fabric that wasn't as thick as the typical foam-backed stuff. It folded over onto itself pretty easily, whereas the foam material was kind of stiff and usually goes down smoother if you're doing it solo.
The sunroof shade is also covered in the same material, but it wound up a little off, but not a big deal, since it's pushed back all of the time.
850oldschool
Chuck, nice looking job on the sedan! That looks like standard foam backed headliner. Where did you source that?
- Chuck W
Thanks. It is. I've usually bought material from https://www.yourautotrim.com/, but there are several sources.850oldschool wrote: 17 May 2020, 14:32 Chuck, nice looking job on the sedan! That looks like standard foam backed headliner. Where did you source that?
- Has thanked: 311 times
- Been thanked: 817 times
It's my beater car - I just rubbed off as much of the decayed foam as could, and re-attached the old fabric. And I didn't worry about where the fabric did not line up perfectly with grab handle cut-outs etc. All done with the headliner still installed in the car.
So there are good reports for both products. I wonder if a big part of the adhesive longevity (for these two products, anyway) comes down to workmanship, getting a good coat on both surfaces.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Does the beige color match up pretty well?Chuck W wrote: 17 May 2020, 15:47Thanks. It is. I've usually bought material from https://www.yourautotrim.com/, but there are several sources.850oldschool wrote: 17 May 2020, 14:32 Chuck, nice looking job on the sedan! That looks like standard foam backed headliner. Where did you source that?
- Chuck W
I couldn't tell you, as I absolutely HATE that light color of the upper interior on these things, so I ditched it for a dark grey/charcoal color and also dyed the upper plastics that needed to match.
They do have a wide offering though, and will send you samples.
850oldschool
Chack, interesting you should mention that. I was just sitting in the car yesterday looking up at the dome light and handles thinking about how they just barely agree with the stock headliner color. They have a warmer tone than the grays in the rest of the interior. Maybe they work better with the 3960 colors. I'd never thought of dyeing the upper plastics until now.
- 818 Views
Last post by E Showell
- 4382 Views
Last post by RobsS40
- 4865 Views
Last post by veektor
- 1217 Views
Last post by markone
- 386 Views
Last post by Baptiste1106
