I've seen similar symptoms but not a clear solution:
06 V70R - just been through Timing Belt, PCV, struts, radiator.......
If it is a few degrees below freezing - cold start is fine - but once the engine tries to slow and idle down (after about 1 min) it almost stalls, recovers, and almost stalls - does this for a few minutes until the engine is warmer, once fully warm it is just fine.
I have VIDA, and may try to observe fuel/02's but have not actively run vida this way yet.
Kind of tricky to trouble shoot because after it is warm, the symptoms are gone.
Also not a lot of fun booting up the laptop to watch in the morning when you are trying to get somewhere.....
Any suggestions appreciated.
Cold Start ok, almost stall during warm up, then fine when warm
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
sounds like the ETM to me?..there is a test on VIDA
2001 XC70 factory M58
2002 XC70 auto (parts car)
- RickHaleParker
- Been thanked: 977 times
When was the last time you cleaned the idle control valve?
Active
Past
Past
- 1909 Views
Last post by volvolugnut
- 1066 Views
Last post by bangusto
- 366 Views
Last post by jonesg
- 746 Views
Last post by doublebug
- 1598 Views
Last post by Ibron
