Xc60 D4 ECT sensor location.
Ghizmo
Year and Model: Xc60 2016
Post by Ghizmo »
Hi!
I have been searching like crazy and I cannot find where the ECT sensor(cooling sensor) is on a 2016 D4 XC60.
Any help would be very appreciated.
Fingers crossed.
RickHaleParker
Been thanked: 981 times
Post by RickHaleParker »
Active
Past
Ghizmo
Post by Ghizmo »
Thank you very much!
Would it be possible to get a simmilar picture (I assume it's from Vida) on where the thermostat is and how to take it off/check it out?
RickHaleParker
Ghizmo wrote: 18 May 2020, 04:40 Would it be possible to get a simmilar picture (I assume it's from Vida) on where the thermostat is and how to take it off/check it out?
See the attached file.
2016_XC60_D4_ECT.pdf
(163.32 KiB) Downloaded 385 times
Active
Past
Ghizmo
Post by Ghizmo »
Thanx dude. I see that this is for the D4204T5 engine. Mine is D4204T14. Should I assume it's the same procedure and that the thermostat is in the same position?
RickHaleParker
Ghizmo wrote: 18 May 2020, 05:59 Thanx dude. I see that this is for the D4204T5 engine. Mine is D4204T14. Should I assume it's the same procedure and that the thermostat is in the same position?
The downloaded VIDA only goes to 2015. The D4204T11 is the same for sure.
Go here and read at least pages 1, 6 & 16.
Active
Past
Ghizmo
Post by Ghizmo »
Thanx again.
Hope you have a great day :)
