https://static.nhtsa.gov/odi/rcl/2020/R ... 6-6561.PDF
Brand / Trade 1 : Pittsburgh Automotive
Model : 6 Ton Heavy Duty Steel Jack Stands
Part No. : 61197
Function : Jack Stand
Descriptive Information : After ongoing quality testing, inspection and assurance reviews of 6 Ton Heavy Duty Steel Jack Stands manufactured by Jiaxing Golden Roc Tools Co., Ltd
(exported by Shanghai Shen Da Import and Export Co Ltd.), it was determined
that product quality had become inconsistent due to aging of the tooling. All jack
stands imported from the manufacturer as part number 61197 are included in
the recall population. Although we believe this issue arose in more recent
production batches, because we are not able confirm that earlier production
units do not have this issue, out of an abundance of caution we are recalling all
units prior to the recall date.
Harbor Freight Tools sells 6 ton jack stands made by other manufacturers, and
we are in the process of evaluating those other jack stands. However, their
evaluation has been delayed by the work restrictions caused by COVID-19. We
have reviewed the history of any customer incidents for the jack stands produced
by the other manufacturers and found that there have not been any other claims
exhibiting the defect. Harbor Freight Tools will update this report after the
review of the 6 ton jack stands produced by our other manufacturers.
Production Dates : JUN 13, 2013 - NOV 22, 2019
Harbor Freight Jack Stands Recalled for Risk of Collapsing
- Has thanked: 2857 times
- Been thanked: 1332 times
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
I bought a set of 6 ton there in December but apparently I got a different lot number.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Good. Keep an eye on this in case they expand it. I'll keep an eye out.
Our family friend, a dad of 3 girls, died under his MG while working on it, circa 1990. I've mentioned this here before a few times. Don't mean to overdo it. Just a reminder to all.
Matty Moo
I asked the dude at HF years ago why they have several lot numbers for the same thing... He said they have several manufacturers making the same part, so each manufacturer is assigned a different lot number.
2000 s70 GLT
2014 Ram
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
I used to have those metal ramps from HF. First time I drove up on them they collapsed a bit. Used them for a while but always had a jackstand somewhere in there for piece of mind. Finally tossed them and bought Rhinoramps instead.
They sell a lot of $hitty products and apparently also fatally bad ones.
BMW 540i 2002
S70 Base 2000
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Returned my Quick Jacks from Costco. Squeaking and son always put jack stands (only have 2) under the front or rear just in case. Almost purchase 2 sets of the HF units for greater weight capacity and height but have always thought there was a possibility them coming down if you bump the handle wrong. I did some research and price comparison and found some with safeties on Amazon so purchased 2 sets of them instead. Remembered the old round ones with the pin.
https://www.harborfreight.com/6-ton-ste ... =go_social
Pro-LifT T-6906D Double Pin Jack Stand - 6 Ton, 1 Pack
https://www.amazon.com/gp/product/B074R ... UTF8&psc=1
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
MoVolvos wrote: 20 May 2020, 00:06 -
Did you not like the quickjack?
- Been thanked: 504 times
For each side, I always use 2 jack stands:
- One 4-leg jack stand (the weakest point of this jack is always at the welding seam, search youtube for test on it using hydraulic press).
- One screw jack stand, cranked up so it shares 50% of the load.
Photos in forum...
Photos in forum...
This video is extreme (hydraulic press), but you can see if any part that fails first, it is the welding seam...
At 0:28 time, the jack stand split...
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
I bought a pair of Esco jackstands shortly after I got my first 850. I love the heavy duty
rubber pad on top and the pin style height adjustment:
https://esco.net/products/esco-3-ton-pe ... ack-stand/
