- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
Looks good, alot of people on the on the FB v70 group paint them an ugly saturated bright red or blue
07 V50 T5 AWD M66 ~146k miles
- Has thanked: 317 times
- Been thanked: 531 times
I like it! The gray looks nice.kallekula wrote: 20 May 2020, 07:58 Last night I painted some of the engine plastic too. Not sure what I think about it yet.
- RickHaleParker
- Been thanked: 981 times
I think it would pop if you polish the Aluminum head with Stove Black wood stove polish. I cannot say for sure how well Stove Black will work on Aluminum. You might want to test it on a piece of scrap Aluminum before you commit to it. If it works ... Black intake also?
Active
Past
Past
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
Wow! ok. I'm not really the wax-on wax-off type of guy. Im the guy that's awkwardly ocd about oil leaksRickHaleParker wrote: 20 May 2020, 19:34I think it would pop if you polish the Aluminum head with Stove Black wood stove polish. I cannot say for sure how well Stove Black will work on Aluminum. You might want to test it on a piece of scrap Aluminum before you commit to it. If it works ... Black intake also?
Anyway, very interesting tips. I think I will youtube that stuff right away. Not sure about intake color but who knows. Maybe I'll try learning a little bit photo shop so I can get some ideas.
Thank you and have a nice evening Sir!
BMW 540i 2002
S70 Base 2000
- kallekula
A little follow up:kallekula wrote: 19 May 2020, 20:34 Noticed that thermostat gasket had started leaking a bit so I decided to replace that and also all the coolant hoses that were starting to look a bit rotten.
The thermostat rubber seal was rock hard and fell to pieces when I took it off. The brand was for sure Reinz because it came in a head gasket kit of brand Victor Reinz that I bought and used 8 years ago. The engine has only been driven 50K miles since then.
Should that be called normal or bad quality?
BMW 540i 2002
S70 Base 2000
I’d say 50k miles for an aftermarket thermostat gasket that costs probably $2 is good. I mean, the OE gaskets usually last longer, but I guess 50k isn’t too bad.
- Has thanked: 1613 times
- Been thanked: 4078 times
That would be every two years of driving for me, for a part which if it dumps your coolant can mean $2000 of engine work, and can’t be easily inspected.kallekula wrote: 20 May 2020, 23:04A little follow up:kallekula wrote: 19 May 2020, 20:34 Noticed that thermostat gasket had started leaking a bit so I decided to replace that and also all the coolant hoses that were starting to look a bit rotten.
I would fall into the “ bad quality” camp
I drove the T5 470 miles around upstate NY ona beautiful spring day. Stopped at cabin and mowed lawn since I fired the lawn service, two socially distanced outside meetings.
