AOC Haldex 3rd gen. How to open it?
Metallo
Year and Model: XC 70 AWD 2.5 - 2006
Has thanked: 7 times
Been thanked: 6 times
Post by Metallo »
Hi there,
Has anybody been able to open the Haldex for repair?
Any way to remove the black plastic cover?
Thank you!
Alex
Polar 940 Turbo SW - 1997
- Pete -
Has thanked: 80 times
Been thanked: 175 times
Post by - Pete - »
They do come apart, I have not tried (yet) but I do have 2 old pumps I need to (attempt to) rebuild. A member in the XC90 forum did a write up on the AOC pump tear down a little while ago. I’ll try to find it.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
Metallo
Post by Metallo »
Hi Pete,
I appreciate your help, I was unable to find any write up about this on the Internet or in this forum, but sometimes is not easy to find what you want, we may use different wording.
Thanks again for your help!
Alex
- Pete -
Post by - Pete - »
I have come across some good info using translator. Most of it seems to come from Russia/Ukraine/Czech Republic.
I have a bunch of Haldex/AOC threads saved somewhere but here’s the one I was referring to earlier.
viewtopic.php?f=10&t=93479
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
Metallo
Post by Metallo »
Thank you Pete, I will check it out and see if I find any useful hint on how to open that thing.
Alex
greffel
Year and Model: 2003 S60
Has thanked: 11 times
Been thanked: 7 times
Post by greffel »
To remove the pump did you remove the cardan
shaft and exhaust ?
Polestar 2 - All electric daily driver :shock:
S60 2.5T AWD with a little bit more power :evil:
- Pete -
Post by - Pete - »
Exhaust isn’t mandatory to remove, but you must free at least the rear CV joint on the driveshaft from the oscillation damper on the AOC/Haldex input. After that, must remove oscillation damper itself. Some cars had a shallower oscillation dampers & it was possible to remove just the rear CVJ. Others had a deeper cup to the oscillation damper & it was mandatory to free the front CVJ from bevel gear output flange first before freeing rear CVJ. All XC’s I’ve seen have the deeper cup. My VR has the shallow cup.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
XC70Rider
Year and Model: 2007 XC70
Has thanked: 35 times
Been thanked: 41 times
Post by XC70Rider »
As Pete said you don't need to remove the exhaust to access the Haldex. I let the exhaust hang a foot and rested the muffler on a jackstand. The downpipe between manifold and CAT is robust and can take a good bend. I have the deep oscillation damper so had to remove the CV joint from the front bevel gear first.
greffel
Post by greffel »
If I only want to do a oil and filter change, is the filter changeable without removing anything else?
- Pete -
Post by - Pete - »
No, removing the flange must be done first, but you can change the filter without pulling the pump.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
