Real Trouble E5 screw on ABS module
Faust
Year and Model: xc70 2008
Has thanked: 31 times
Been thanked: 10 times
Post by Faust »
2004 V70 NA While trying to replace the ABS module, I finally made the big mistake. Since the unit is mounted upside down, I accidently tightened one of the mounting screws. This managed to bugger the splines. Can anyone suggest a way that I can get a grip on the E5 torx screw. I know about the 5/32ds interchange, but that doesn't hold either. I have a replacement screw for the one I messed up.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
Has thanked: 1611 times
Been thanked: 4072 times
You should be able to get a vice grip on it and remove.
Faust
Post by Faust »
The screws are centered in "reliefs" in the plastic module. No vice grips I have seen could find the area around the screws required. I am considering trying to get a grip with small wire cutters. Had the same problem in removing the module from my "parts" Volvo. I ended up having to remove the entire unit and drill out the screw. Don't want to repeat that.
2004 V70
You could try JB welding the socket onto the fastener as a last resort before removing it.
Ugh. Forgot about the recess
Been thanked: 504 times
Post by cn90 »
I posted the trick in P80 forum.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
A Left hand drill bit with the drill in reverse will most likely will spin the bolt out. Go slow and make sure you get the bit centered so it does not snap when the bolt turns.
Active
Past
Faust
Post by Faust »
Thanks for the suggestion. I have the left hand drills. But, aside from being upside down, the E5 head is so small, I dcould never center it. Before I had to take the entire unit out and lock it in my drill press to even approximate center.
2004 V70
Faust
Post by Faust »
cn90 wrote: 22 May 2020, 06:29 I posted the trick in P80 forum.
I did a search and assume it was the post about using an E6. Failing that, I will try the JB Weld suggestion. I have sockets and bolts to spare. Although before reassembly I think I will also get the bolts you suggested from ACE, why go through this twice?
2004 V70
chris11211
Year and Model: 2006 s60 2.5T
Has thanked: 7 times
Been thanked: 29 times
Post by chris11211 »
try 4mm socket (or whatever mm fits it) it'll grip the same.
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
I think you need to remove the whole unit,sorry. the copper lines are flexible so might be able to get a better angle view on the problem.
2001 XC70 factory M58
2002 XC70 auto (parts car)
