So I'm at a loss. I have a 2003 V70 T5 that has been sitting for close to 2yrs. Somewhere along the way the original keys were lost and being the broke student I am, I decided to get resourceful rather than go to Volvo for $400 worth of new keys and programming.
I went to my local junk yard and found a door lock, ignition lock and key for $20. Knowing Volvo and their anti-theft systems, I also grabbed the antenna ring around the ignition switch. Now, I finally got everything installed (NOT EASY TO DO) and went to turn the key and not so much as a clicking starter. Unfortunately, the previous owner (my father) tried swapping a R cluster into it and I found out that the little message area in the bottom left corner doesn't work. So I can't even tell if its the immobilizer. I also don't know how to reset the immobilizer without a key fob
Long story short... I'm wondering if there's another piece to the anti theft system that I didn't grab. Something specific to each car??
2003 V70 T5 Key Swap
Mountainman45
- Year and Model: 01 V70XC
- Has thanked: 2 times
- Been thanked: 4069 times
Inside the key Is an RF chip which will only work with an ECU that is programmed to accept it.
From 1999 on, you need VIDA and a server connection to program an ECU to accept a key.
Losing a key on a Volvo is a painful, expensive lesson
Mountainman45
Oh I have access to people with Vida. It's not the worst thing in the world. I also PERSONALLY have access to a Snap-On Verus Diagnostic Center at work. (Can read as many things as Vida if not more) I should be able to program it tomorrow at work.
Now sightly off topic, the instrument cluster.... Do I also need Vida to mate it to the car?
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
Member Yagger does this sort of work very regularly & his rates are very affordable. He doesn’t post much, so maybe send him a PM.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
You need all of: VIDA Online active subscription, new (empty) key, bar code sticker from the packet with the key. The immobilizer chip is programmed once, after that it can't be reprogrammed.
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
I hope you have better luck than me, i emailed a few key cutting places that say they do Volvo keys/RFID programming but no reply after 1 week. I have bought two P2 cars and with each car only given one key. I think the RFID chips in many keys stopped working. Its an expensive trip to the dealer if you cant get anyone online to do it.
2001 XC70 factory M58
2002 XC70 auto (parts car)
They key is about $50 programmed at a good independent with VIDA AND SERVER subscription.
The fob is more expensive
- darrylrobert
For anyone wanting the "R" blue facia cluster look to replace your standard DIM, the best way is to take apart your original working DIM and remove/swap the gauges, it should work. If it doesnt remove the gauge needle and replace the facia (it peels off ).
It may be possible to buy the facia aftermarket?
Mountainman45
So here's a wild concept.... I've been doing some digging around the wiring diagrams and such and came to an odd conclusion.. if the part numbers are the same what's stopping me from simply pulling the CEM out of the donor car. Since it already has the key programmed into it and it's also a v70. Is there anything mated VIN-wise to the ECU?
The CEM IS CODED vin specific.
Xemodex can reprogram a CEM Vida cloning if you want a match a current one.
