How do my Delta Link Bushings look to you?
my98s70glt
- Year and Model: 99 V70R, 07 V70 2.5T
- Has thanked: 11 times
- Been thanked: 5 times
FCP has them as well... https://www.fcpeuro.com/products/volvo- ... vo-9995497
Current:
1999 V70R: Signal Red/Charcoal || Snabb RIP Kit || Snabb Air Intake || Simons Axleback Dual Exhaust
2007 V70 2.5T: Snabb Fresh Air Pipe || BC Racing Coilovers
Previous: 1998 S70 GLT, 2006 V70 2.5T, 2011 C70 T5, 2012 S60 T5, 2000 S70 GLT/SE
- Been thanked: 4068 times
I wonder if you bust the tool, is it still under the FCP warranty program?my98s70glt wrote: 26 May 2020, 10:43 FCP has them as well... https://www.fcpeuro.com/products/volvo- ... vo-9995497
my98s70glt
Funny you should ask... the threaded shaft bent while removing the second bushing (this was before I knew extreme heat was my friend). Since I owned it for a whopping one week and used only on my car they issued me a store credit.abscate wrote: 26 May 2020, 11:34I wonder if you bust the tool, is it still under the FCP warranty program?my98s70glt wrote: 26 May 2020, 10:43 FCP has them as well... https://www.fcpeuro.com/products/volvo- ... vo-9995497
- 6D5C832D-4FA4-4C6D-93D2-65BFFCDDC673.jpeg (210.23 KiB) Viewed 1480 times
Current:
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Did this require a breaker bar or an impact driver?
my98s70glt
I used a breaker bar, it was a bear of a job without using enough heat to melt the outer plastic shell on the bushing.
Current:
Archer
- Year and Model: 2002 V70/S60 T5
Are these these not the trailing arm bushings...?
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
They say not to use an impact driver on those tools...
I run a drill bit through the plastic bushing sleeve on the top of the bushing.
It allows the shell to break away from the arm. Also, it leaves no melted mess.
The force required to bend that is crazy...my98s70glt wrote: 26 May 2020, 15:09Funny you should ask... the threaded shaft bent while removing the second bushing (this was before I knew extreme heat was my friend). Since I owned it for a whopping one week and used only on my car they issued me a store credit.abscate wrote: 26 May 2020, 11:34I wonder if you bust the tool, is it still under the FCP warranty program?my98s70glt wrote: 26 May 2020, 10:43 FCP has them as well... https://www.fcpeuro.com/products/volvo- ... vo-9995497
redbeak1
- Year and Model: 850t5 1996
- Has thanked: 7 times
- Been thanked: 2 times
I bought mine from IPD. It was such a challenge getting them out, that I stripped the threads on the tool. I think the picture you are showing is the transverse arm bushings. On my 96 850 the rubber looked good but the metal bracket was broken.
