Just remove it and blow through it in both directions....if it's closed...it's good.
If you can blow through it,it's bad and stuck open.
It's unpowered state is closed.
96 850T5 Hard restart after engine is hot in hot weather.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
redbeak1
- Year and Model: 850t5 1996
- Has thanked: 7 times
- Been thanked: 2 times
I can not blow through in the direction of the arrow, but I can in the opposite direction. What does this tell you?misha wrote: 27 May 2020, 10:04 Just remove it and blow through it in both directions....if it's closed...it's good.
- misha
Did you disconnected it's connector during this test?
It should be closed in both directions when disconnected.
Arrow is pointing towards intake manifold?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
redbeak1
Yes, I removed it from the car. Arrow is pointing toward manifold when installed. I used very light compressed air. I could not get air through it in the direction of the arrow, but I was able to... going in the opposite direction. I would think that this is a one direction valve when activated.
93ForMe
- Year and Model: 1993 850
- Been thanked: 17 times
Hi redbeak1,
I am having similar issues, and I think I may have had a break-though with it today.
My problem seemed very temperature related, but I had switched out the ECT sensor and they persisted. Today I pulled apart the female connector that the ECT plugs into and found that the sheath around the female barrel connectors had started to break down. I cut it away at the base and found a whole lot of corrosion that I cleaned out. Corrosion will increase resistance and make your car think that it is colder than it is. Cold starts, no problem. Hot starts, problem.
Here is my thread, I have a couple of links to pictures of the connector:
viewtopic.php?f=1&t=93975&start=20#p543693
- Has thanked: 316 times
- Been thanked: 531 times
That's a good point. Corrosion on this connector is very common on 850s, it's definitely worth a careful look.93ForMe wrote: 27 May 2020, 18:02 Hi redbeak1,
redbeak1
Hi 93Forme, I read your thread a couple of times. Our problems are similar but not exact. My car has to get really hot. A run on the highway pulling a trailer in 80 degree weather and stopping for a 20 minute break would cause a hard start issue. It seems from your thread that once your car is past being warmed up, and is hot, it runs fine.93ForMe wrote: 27 May 2020, 18:02 Hi redbeak1,
I once had a intermittent cut off of the engine problem that went on for a long time. I replaced the Fuel Injection relay(the grey one above the radiator). The problem turned out to be the defective new relay. I went nuts checking everything else. I had to wait for the engine to be completely dead before troubleshooting led me back to the same relay that was changed. The Bosch factory didn't do a good job soldering inside the relay. Once the engine was hot and I would hit a bump on the highway the engine died. I cleared the code which came up as a Throttle position sensor that was also replaced. After that the engine ran fine, but would cut out rarely until resolved.
I really hope it turns out to be the wiring in your car. After over 25 years, we can't complain that some plastics start to degrade. Otherwise these cars are tanks. I will also check that same ECT connection tomorrow.
I will keep everyone posted if I can resolve this, especially since we are going into summer!!
redbeak1
Hi Misha, would you conclude that if I can blow through it in the opposite direction of the arrow, that the valve is no good? Thank you for all your help.misha wrote: 27 May 2020, 10:04 Just remove it and blow through it in both directions....if it's closed...it's good.
- misha
Just checked mine.....closed in both directions when engine is not running.
Your's could be failing....since it's closed in just one direction.
Here you can see that a good evap valve is closed in both directions:
https://volvo850wagon.wordpress.com/tag/evap/
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
redbeak1
misha wrote: 28 May 2020, 17:16 Just checked mine.....closed in both directions when engine is not running.
Thank you-thank you so much!! You and everyone on this forum has helped so much. I will report back with any new findings.
- 20 Replies
- 654 Views
Last post by cn90
- 10 Replies
- 1540 Views
Last post by rguzz
- 704 Views
Last post by MoVolvos
- 18 Replies
- 5626 Views
Last post by regent
- 2085 Views
Last post by Bdsexton06
