Need roof hatch "bezel" that secures the roof lining
- Has thanked: 316 times
- Been thanked: 531 times
That may work. I'd say try to get a little headliner adhesive on there, but the spray is hard to control.
- RickHaleParker
- Been thanked: 977 times
Redo the whole headliner and be done with it. Otherwise you will be coming to patch it over and over as the sagging weight pulls it down.850forum wrote: 27 May 2020, 20:11 Maybe use some rubber cement; I have that and thinner, make up a runny solution and stick the headliner all the way around the edge
Active
Past
Past
850forum
- Year and Model: 1995 850 turbo wagon
- Been thanked: 6 times
Well crap. Seller cancelled the order, says not available. But its still up for sale on eBay...
I see an "08 2008 XC90 " trim for sale, guess it won't fit.
Seems that the bezel is the same for ??? :::
Genuine Volvo Sunroof Trim 9193482
fits
850
V70
S70
C70
fits
850
V70
S70
C70
NEVER OPEN THE HOOD !!!
- RickHaleParker
It is the same for all Platform 80 cars. P80 = 850 series and first generation 70 series. The first generation 70 series is a restyled 850.850forum wrote: 06 Jun 2020, 04:36 Seems that the bezel is the same for ??? :::
fits
850
V70
S70
C70
P80 70 series cars.
V70 1996–2000.
S70 1996–2000.
C70 1996–2005.
Active
Past
Past
DrJammer
- Year and Model: 2000 V70XC - 195k
Maybe try the 3M product that is used to hold corner bead on walls. a type of spray adhesive, but unsure how it works on fabric, plus it's usually tinted. it is a light spray glue that has saved me in other applications
Ex-Volvos
2004 v70 N/A - traded in at 75k
2008 S60 - leased
1998 S70 T5 - might still have her if I knew about this forum when I owned it
2008 S60 - leased
- Has thanked: 311 times
- Been thanked: 817 times
It is common for this piece to explode into pieces upon removal, so keep that in mind if you go the junkyard route. Maybe plan on pulling several before you get one in few enough pieces to be usable with glue. And glued in means likely not coming back out so ...
It's also common for the headliners to separate at this age, as Rick alluded to. Getting the bezel/trim piece off without ruining it is the crux of a headliner repair job on these P80 cars. Since the piece is already off on yours then now may be the time to replace the fabric.
- RickHaleParker
JB Weld for plastic to put one back together. Then a thin layer on the back side for reinforcement. Still I think the real savior for Tupperware cars is going to be the 3D printer.erikv11 wrote: 11 Jun 2020, 00:46 Maybe plan on pulling several before you get one in few enough pieces to be usable with glue. And glued in means likely not coming back out so ...
Active
Past
Past
DrJammer
If you'd like, I can try to remove the sunroof trim on my 2000 XC prior to it disappearing.
Ex-Volvos
2008 S60 - leased
2008 S60 - leased
850forum
That would be helpful even if you just send me broken pieces. I have a couple of pieces from mine, and I could try to piece them together, and add some sort of support at the glue lines.DrJammer wrote: 11 Jun 2020, 08:36 If you'd like, I can try to remove the sunroof trim on my 2000 XC prior to it disappearing.
- 1051 Views
Last post by Biaspot
- 400 Views
Last post by mjvracing83
- 672 Views
Last post by drwingnut
- 719 Views
Last post by SuperHerman
- 1632 Views
Last post by pedal2metal
