The Typical Odometer Issue
jaiden19
Year and Model: 1994 850
Post by jaiden19 »
Hello there, so I am a new, proud owner of a 1994 Volvo 850 Turbo. I bought the car with a broken odometer. I recently decided to change the odometer gear, but this did not fix my issue. Whenever I reset the trip gauge on the odometer and drive the car, it looks as if it hesitates to move, but stays stuck at zero and the odometer does not move at all. Does anyone know a fix for this?
ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
Were you able to advance it manually when you had it out?
Has thanked: 292 times
Been thanked: 765 times
My first guess is the second gear is broken or the repair swap didn't go properly. OK my first two guesses.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
Also, there are different gears. Thy differ by the amount of teeth they have.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
