Pcv, breather box help
TyRawr
- Year and Model: 2003 S60 2.5 Awd
- Has thanked: 14 times
Re: Pcv, breather box help
Thank you. I didn't know that that's how the coolant flowed through that pipe. When installing new banjo bolts do I need to line them up so the hole in the bolt is facing the hole in the pipe?
- Has thanked: 1504 times
- Been thanked: 3817 times
No, a banjo will flow no matter the orientation.
Technically, since there are two, they are dualing banjos
MVSatire
MVSatire
TyRawr
So i replaced the pcv coolant hose, breather box, coil packs, and the spark plugs and the car is still telling me I have a p0300, p0301, p0302, p0304. Which is misfires. But how can I replace all that and still have this problem?
- - Pete -
- Has thanked: 80 times
- Been thanked: 175 times
What are you using to pull codes?
I assume it is running very poorly, or barely at all?
You’ve ensured that all the wires that go to the coils aren’t pinched or severed somewhere?
I suspect there are other codes that you may not be able to see, if using a basic reader.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
TyRawr
Replaced the spark plugs, coil packs, coil pack wire harness, checked injectors, wired in new fuel rail wire harness. Problem still persists. Codes. P0300, p0301, p0302, p0304
Thinking head gasket needs replacing.
And cleaning that manifold really makes a difference. Before and after pics.
- Has thanked: 927 times
- Been thanked: 1000 times
What did you use to clean the intake manifold? It sure looks great.
- - Pete -
I have a couple questions for you.
I can’t tell on the coils; I tried zooming in on the high resolution images but I can’t quite make out if there is any writing on the tops of the coils. If they are no-name-brand/Chinese cheap coils, they will be blank & I would not be surprised if one or more of them are dead right out of the box. Also, what did you go with for plugs?
Now, before you buy more coils, have you checked your compression? Did you take a close look at your injectors, & possibly clean them?
From the looks of it you are doing very meticulous work, nice job on the wire loom!
Also, nice job on the intake plenum! Most of mine have mouse piss & years of ugly stuff on them
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- 15 Replies
- 2584 Views
Last post by Bluevanacd2005
- 4035 Views
Last post by jamadams11
