2004 S60R B8444S (V8) conversion (Previously : Exhaust Manifold removal.)
This topic is in the MVS Volvo Repair Database » 2004 S60R -- Yamaha V8 Conversion!
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Came across this on FB this morning, I was excited to see another B8444S swap in a P2R!
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
bmdubya1198 wrote: 29 May 2020, 09:28 Came across this on FB this morning, I was excited to see another B8444S swap in a P2R!
Is he doing engine and transmission?
I'm getting there.
Active
Past
bmdubya1198
Yup, he’s doing an M66.
RickHaleParker
bmdubya1198 wrote: 29 May 2020, 22:47 Yup, he’s doing an M66.
I had a chat with him on Facebook. He is starting off with a 2006 S60R. His electrical, electronics and software should be pretty much plug and play. I told him where to find MVS and Yagger if he runs into a problem.
The B5254t4 is shot. Sometime between when I got it and how, it went to full lock up. Most likely the Antifreeze in the crankcase rusted everything in the lower end.
Active
Past
bmdubya1198
Yeah, that motor was junk.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1076 times
Post by volvolugnut »
Now what? Find another V8?
bmdubya1198
volvolugnut wrote: 31 May 2020, 18:56 Now what? Find another V8?
Nah, he’s talking about the B5254T4. The original motor.
RickHaleParker
The original 2.5L is now locked up, I could turn it over when I got it.
If you look above I was think of salvaging the internals in case somebody wanted them. Pistons new are $160.00 each. Connecting rods new are $200.00 each.
Active
Past
RickHaleParker
Notes: In 2005 Volvo changed the High Speed CAN bus speed from 250 Kbps to 500 Kbps.
Control modules on the HS bus: ABS/BCM, DEM, ECM, ETM, SAS & TCM.
Active
Past
Been thanked: 4069 times
I’ve got one of those them there fast 2005 Busses.
