Crank no start...... but will start
Littlelegs
Year and Model: V70 T5 2001
Post by Littlelegs »
Hi everyone, so this is my first forum ever ! Please be patient with me 🙏
I have recently purchased a V70 T5 2001 manual ... it has a few issues of which I’m working my way through.
The biggest issue I have at the moment is .. it will crank but no start.... however if you mess with the cranking times with the key it will start. Once started it’s perfect. I have good pressure at the rail, I’ve changed all injectors, it has a new crankshaft position sensor, a new cam sensor, new battery.
Any ideas where to go next.... many thanks
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Old starter may create a lot of interference in crankshaft position sensor. ECU does not see CPS -> does not know when to start firing.
Littlelegs
Thanks for that, will be my next job 👍
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
Interference is most likely. does it do it in hot weather? above 25c. Have you had the "start inhibited try again" message then check the key transponder/imobiliser.
2001 XC70 factory M58
2002 XC70 auto (parts car)
Littlelegs
Hi there
Thanks for the reply.... I should have added that I’ve changed the halo as the very first job. Also I’m in England so 25c doesn’t happen that often 😂🤣😂
I’m waiting for delivery of my new starter and will let you know how it goes. Thanks again
darrylrobert
I dont think its the starter as much as the Crank sensor wiring that goes near it. If my car continues to exibit this "hard starting" that will be my next attempt at a fix. Also removing the ECM and cleaning the pins.
Littlelegs
Hi everyone
Just an update.... many thanks for the advice on the starter motor.... have changed it for a new one.... instant starting.....
Many thanks
Steve
darrylrobert
Nice, when you had the starter out did you notice any build up of what looks like clutch disk material in the bellhousing?
Littlelegs
Not to any great amount, flywheel teeth were a bit worn and getting the intercooler pipe back on the throttle body was a pig.....
