31401351 fits 2005 & 2006 V50 2.4l & 2.5l 5 cylinder. It is clear not what year you have, your profile says 2005 and your post says 2006. Look at the 6th & 7th digits of the VIN number. 38 = B5244S4, 39 = B5244S7, 68 = B5254T3.brushhippie wrote: 25 May 2020, 12:28 I believe they are part number 31401351 also need the two green rubber gaskets that go between the cover and head..have not found the number (or name) for those anywhere.
As for the green gaskets post a picture of the gaskets. I cannot think of any gaskets other then the O-rings and liquid gasket the goes between the cam cover and head.
this one only has the one so the little gasket was between the cam cover and the head in that little indention
although I do not really see why it would be needed.
