Radiator protection?
- June
- Has thanked: 523 times
- Been thanked: 261 times
I'm not sure about "lifting the front end" as Oragex mentioned. My dealer simply replaced the springs, struts, and related hardware which brought my cars front end back to it's original height. In fact after replacement my car drove better than it had in years. I tend to zip down the highway 90mph+ rather consistently without issue. Usually I don't even realize I'm driving that fast. So replacing front end parts with factory parts should not lift your Volvo. Just bring it back to its original stance which allows it to clear parking barriers once again. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Agreed. My V70 also gained at least an inch with new springs and shocks all around.June wrote: 03 Jun 2020, 07:31 I'm not sure about "lifting the front end" as Oragex mentioned. My dealer simply replaced the springs, struts, and related hardware which brought my cars front end back to it's original height. In fact after replacement my car drove better than it had in years. I tend to zip down the highway 90mph+ rather consistently without issue. Usually I don't even realize I'm driving that fast. So replacing front end parts with factory parts should not lift your Volvo. Just bring it back to its original stance which allows it to clear parking barriers once again. June
But those barrier things seem like a terribly poor design to me. Either just don't or make them high enough to be seen.
- June
Here in the US those barriers are from a time Americans drove cars like these. JuneRattnalle wrote: 03 Jun 2020, 08:24Agreed. My V70 also gained at least an inch with new springs and shocks all around.June wrote: 03 Jun 2020, 07:31 I'm not sure about "lifting the front end" as Oragex mentioned. My dealer simply replaced the springs, struts, and related hardware which brought my cars front end back to it's original height. In fact after replacement my car drove better than it had in years. I tend to zip down the highway 90mph+ rather consistently without issue. Usually I don't even realize I'm driving that fast. So replacing front end parts with factory parts should not lift your Volvo. Just bring it back to its original stance which allows it to clear parking barriers once again. June
But those barrier things seem like a terribly poor design to me. Either just don't or make them high enough to be seen.![]()
- 20200603_102930.jpg (176.25 KiB) Viewed 1455 times
- 20200603_102946.jpg (261.81 KiB) Viewed 1455 times
My Volvo cars owned
1996 960 ordered
1996 960 ordered
Faust
- Year and Model: xc70 2008
- Has thanked: 31 times
- Been thanked: 10 times
The fact that the cars are known to 'sink" is still further reason to provide some protection for the radiator. Making the job of replacement a little easier wouldn't hurt either.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
- June
I agree! JuneFaust wrote: 03 Jun 2020, 08:34 The fact that the cars are known to 'sink" is still further reason to provide some protection for the radiator. Making the job of replacement a little easier wouldn't hurt either.
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
Faust, if your radiator separated/cracked where the plastic end tanks meet the aluminum radiator body, did you take a close look at the intercooler & condenser also?
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
Faust
No, I will inspect them when the radiator is removed. I have done this so many times that I don't anticipate any damage. This is my 4th V70 radiator. (two to the same parking barrier, what does that say about me?)
2004 V70
- June
Since I am out shopping I took some pictures of my car vs. barricade clearance. My struts/springs were replaced back in 2017/18 at about 150K miles. Now at 198K and a couple of years notice how much clearance I have. Also note my rear suspension is completely factory never touched and the car front end is not too high for the rear. Notice other cars parked next to me cannot clear the barricade, one even backs in as the front bumper would be destroyed due to low angle. Your P2 V70 should clear it like mine. JuneFaust wrote: 03 Jun 2020, 09:15 No, I will inspect them when the radiator is removed. I have done this so many times that I don't anticipate any damage. This is my 4th V70 radiator. (two to the same parking barrier, what does that say about me?)
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- June
My favorite spot was open at Publix and apparently it is a cement curb rather than a barricade. In any event as these pictures show my car still clears the curb fine now. This is the spot where I did my radiator in. Yes Abscate, I'm a crazy woman driver!
June
My Volvo cars owned
1996 960 ordered
1996 960 ordered
Faust
I am not so much concerned with clearance, as I am that the radiator extends below the front "skirt". If that skirt rubbed, I would have some warning. The principal offender (the one that has gotten me twice) seems to be higher than normal. However it doesn't strike the skirt, giving a warning, but catches the radiator.
2004 V70
- 13 Replies
- 2814 Views
- 1726 Views
Last post by cn90
- 15 Replies
- 2633 Views
Last post by vovo850
- 559 Views
Last post by SuperHerman
- 230 Views
Last post by jonesg
