Pcv, breather box help
- Has thanked: 1611 times
- Been thanked: 4075 times
Intake manifold looks great, and that same stuff can clean the cat(s) too.
TyRawr
- Year and Model: 2003 S60 2.5 Awd
- Has thanked: 14 times
They are blank no name coils. I will try and swap them around. And plugs I used bosch platinum. The ones with 4 prongs around the tips and set to recommended nm. The car starts and sounds beautiful on rev but has hiccups on idle And the car heaves in drive or reverse. Like one foot is on gas and one foot is pumping breaks And I have not done a compression test yet. I was looking into how to do that.
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
If, after moving known good coils around, you still have misfiring cylinders I would double check your injectors, and then compression. HF has a very inexpensive compression tester. Accuracy isn’t critical, you just want to see somewhat uniform numbers at this point. Cold you should see somewhere around 90psi.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
With as many misfire codes as you’re getting I wouldn’t be surprised if you don’t have ANY known good coils to swap around. But before dumping a bunch of money on new coils I would be inclined to replace those 4-prong platinum plugs with some good old copper core plugs at $2 a throw.TyRawr wrote: 01 Jun 2020, 11:51 They are blank no name coils. I will try and swap them around. And plugs I used bosch platinum. The ones with 4 prongs around the tips...
- - Pete -
chrism wrote: 03 Jun 2020, 06:47With as many misfire codes as you’re getting I wouldn’t be surprised if you don’t have ANY known good coils to swap around. But before dumping a bunch of money on new coils I would be inclined to replace those 4-prong platinum plugs with some good old copper core plugs at $2 a throw.TyRawr wrote: 01 Jun 2020, 11:51 They are blank no name coils. I will try and swap them around. And plugs I used bosch platinum. The ones with 4 prongs around the tips...
+1
This is what I was getting at earlier. If you still have the original coils that were in there (Bosch/Volvo/Germany/Slovakia) you can identify (by trial & error) which ones are still good. Ohm’ing them is not a definitive test, so do not rely on it. Hopefully between your originals and the no-name ones you can get 5 of them. I would definitely get rid of the no-name coils though. Even used eBay Bosch coils are better than new no-name coils.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
TyRawr
All good information. I'm going to swap around coils when I have time. Between new and old I have 11 coil packs to play with. And what difference will the spark plugs make? They're all brand new and like I said the car sounds amazing minus the misfire
- - Pete -
Plain old single electrode/copper Volvo/Bosch plugs are time tested & proven, especially on turbo models. That being said, it’s most likely that your coils are the problem vs your 4-electrode plugs. Get know good coils in there and then proceed along to trouble shooting.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
TyRawr
I didn't have time to do the cylinder leak down test the other day but just had some time to so here's the results. I put 50psi on each cylinder with each piston at tdc. How do I read this?
- 4744 Views
Last post by jamadams11
- 13 Replies
- 3487 Views
Last post by nickbw898
- 24 Replies
- 5501 Views
Last post by Darkskies65
- 2032 Views
- 1038 Views
Last post by vtl
