Smoke when letting off throttle
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
My smoke was white and ended up being an oil leak in the turbo.
- RickHaleParker
- Been thanked: 980 times
Blue or Blue-Gray and smells like oil? Color and smell are important clues don't fudge over them.
Black Exhaust Smoke is incomplete combustion. Will smell like unburned gas.
White Exhaust Smoke is steam (water).
Antifreeze in the water will give it a sweet smell.
If it is white but not sweet smelling it is condensation burning off.
Blue or Blue-Gray Exhaust Smoke is oil. Will smell like oil burning.
Active
Past
Past
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Try ATP205 for the Valve stem seals.
http://atpautomotive.com/featured/re-seal
However, before doing that switch to Rotella T6. My 98S70T5 use to have a large puff and light smoke for a block at startup and it was due to blowby. During the summer I used a 15W-40 and a 5W-40 in winter. Significantly reduced the smoke and if it does for your car you know it's the piston rings.
The 15W-40 was not Rotella but the T6 is an excellent all year round oil.
https://www.amazon.com/dp/B01LH7L0KS?ta ... e=osi&th=1
- 2038 Views
Last post by pbierre
- 12 Replies
- 5198 Views
Last post by dosbricks
- 13 Replies
- 1988 Views
Last post by misha
- 963 Views
Last post by legacyhunters
- 561 Views
Last post by cn90
