Is anyone running 19+year old starter motors?
Does anyone have some insight/knowledge of electromagnetic interference (emi) from the starter motor messing with the crank sensor wiring. The crank sensor wiring goes past the rear of the starter, there is a fair amount of info online/forums reporting this issue saying an old starter/worn brushes has a higher amount of emi causing starting problems. I believe temperature (heat soak) from the engine makes the emi worse? anyone know?
Would some emi sheilding wrap work or would only a re route of the crank sensor wiring fix it?
19year old starter motor emi
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
2001 XC70 factory M58
2002 XC70 auto (parts car)
- Has thanked: 1506 times
- Been thanked: 3818 times
About 99 percent of people who fuss with the crank sEnsor don’t put the wires back in those nice slots that route it so carefully away from the starter and cables, then complain about bad Volvodesign.
Make sure they go back as designed
I’m running starters from 1999 ( qty 2) , one from 2000, and2002, 2003
All still available, but even if not, how the wires get routed is important
https://www.volvopartswebstore.com/show ... evel=24667
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 115 times
- Been thanked: 185 times
The advice given above is sound and you should start there.
To reduce induced noise on a conductor I would do the following
1. Move the source of the interference away from the receiver of the interference (this is what is recommended above)
2. Position the cables so that they are perpendicular to each other
3. Wrap a return cable on the positive battery to starter cable (search twisted pair to understand how this works)
4. Add extremely large ferrite clamps to the starter wire
5. Add a shield to the wire that is succeptible to the EMI noise And connect both ends of the shield to a good ground
The engineers at Volvo were likely aware of these possibilities and they solved the problem by focusing on item #1.
Assuming that you are trying to make your Volvo more reliable to start and that you are not trying to redesign it then I recommend you focus on item 1 as well.
You didn’t ask but I don’t think a new starter would generate less EMI, which takes us back to the recommendations above
I recommend you thank Abscate and follow his recommendations
Good luck
Paul
Good luck
Paul
- Has thanked: 927 times
- Been thanked: 1001 times
Can you provide a photo of the typical original Volvo design? This will help those poor souls who have lost the motherland wire routing.abscate wrote: ↑07 Jun 2020, 05:37 About 99 percent of people who fuss with the crank sEnsor don’t put the wires back in those nice slots that route it so carefully away from the starter and cables, then complain about bad Volvodesign.
Argggh. Daryl Is down under so we need a RHD cable routing help
Anyone have photo(s) of proper, factory LHD wiring arrangement?
Anyone from UK or Oz have photo(s) of RHD arrangement?
Personally, I would like to confirm my 200K mile, 20 year old has proper cable routing. I know it has been apart several times and some fasteners are changed or missing.
- darrylrobert
I have the plastic bracket that holds the connectors intact, LHD and RHD engines and wiring are the same, engine wiring is the same only the steering wheel/rack /clutch is different. The main problem is the "factory wiring" is routed past the rear of the starter. Theres a video on youtube made from someone in the US
My theory is that this emi problems is worse in hot weather.
darrylrobert wrote: ↑07 Jun 2020, 21:13 I have the plastic bracket that holds the connectors intact, LHD and RHD engines and wiring are the same, engine wiring is the same only the steering wheel/rack /clutch is different. The main problem is the "factory wiring" is routed past the rear of the starter. Theres a video on youtube made from someone in the US
That wiring routing is Not right. They are using the pcv bracket as a wiring bracket.
The wires get tucked into plastic holders that hold the tight along the block at the rear and then turn the corner into connectors on the bracket.
I’ll try get pics
- 941 Views
Last post by skippy764b
- 12 Replies
- 1217 Views
