Reworking an old engine for future projects.
Engine running well but oil return lines heavily sludged. Plan is to remove head, rework
Remove oil pan, renew oring, oil pickup , clean crankcase.
The rebuilding of "Curious George" 2000 B5244T engine
Picture a Gallery
- Has thanked: 2199 times
Ooh!!!!!! Those are ugly cam seal failures on cylinder #5. That poor engine.
Good luck with the clean and repair!
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
No, don't do the RMS! It is way more fun to pull the engine again to do the RMS after you put the engine in the car and find out it leaks... At least that's what I have been told by reliable sources.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Has thanked: 987 times
- Been thanked: 1075 times
RMS = Root Mean Square? Assume this is not what this means in this context.
Rear main sealvolvolugnut wrote: 07 Jun 2020, 13:55 RMS = Root Mean Square? Assume this is not what this means in this context.
$10 part that keep oil of the flywheel and clutch, where applicable, that takes 15 hours of engine R/R to replace
Not in the glossary. We will fix that
I should have known that definition. MVS has a glossary?abscate wrote: 07 Jun 2020, 15:10Rear main sealvolvolugnut wrote: 07 Jun 2020, 13:55 RMS = Root Mean Square? Assume this is not what this means in this context.
https://www.matthewsvolvosite.com/glossary
I’ve linked to it in my sig but the link is broken and my editor is not behaving at moment, either
Tried some hand drilling today and quickly figured out a drill press is needed.
- 1405 Views
Last post by jantt
- 1427 Views
Last post by shiloh51933
- 26 Replies
- 2722 Views
Last post by Kerpre
- 455 Views
Last post by chris11211
- 20 Replies
- 7419 Views
Last post by tonie
