Ive always used carby cleaner on the plastic turbo pipes, however looking at the data sheets using (without acetone) brake cleaner is much safer on plastics/rubber. theres an active ingredient in carby cleaner called TOLUENE that eats most plastics.
Actually i was thinking they were infact the same product under different labels, this is not what i found.
brake cleaner or carby cleaner?
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
2001 XC70 factory M58
2002 XC70 auto (parts car)
Acetone andTCE are in brake cleaner m for degreasing.
I think acetone andABS won’t be a good combination, considering I use it to smooth my ABS finished parts.
Toluene and ABS will be ok if you moisten cloth and wipe out the oil, but don’t immerse it ina swimming pool oftoluene.
Toluene is nasty shinola.....cancer!
Nitrile gloves and do it outside. Keep that spray out of your lungs
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Simple Green and let is soak, problem is it needs be rinsed - careful not to get water on top of the engine, the coils don't seal the spark plug holes
- Has thanked: 987 times
- Been thanked: 1075 times
The older I get the more I worry about chemicals. Good thing. I had some bad habits before I got old and wise. LOL
I hope the young guys listen and don’t repeat our mistakes.
Get those cheap gloves and keep everything off your skin and out of your lungs
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
I agree with everything above. I use brake cleaner quite a lot as a quick degreaser, but I'm starting to question that. I often have it soak through good quality gloves. In years past, I had chapped peeling hands from carb cleaner.
They are both nasty to breathe, and in chilly weather in the garage, I'm not getting any ventilation. I went in to the kitchen for something, went back out into the garage, and the smell hit me like bricks.
- BlackBart
Also - I just used some rust treatment paint for bare steel last night, and it gives you a headache right away. That can't be good.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
correct, gloves can easily allow chemicals to pass, especially if your hands sweat due to the gloves themselves.BlackBart wrote: 08 Jun 2020, 11:21 I agree with everything above. I use brake cleaner quite a lot as a quick degreaser, but I'm starting to question that. I often have it soak through good quality gloves. In years past, I had chapped peeling hands from carb cleaner.
A world expert on toxicology spilled 2 drops of organic mercury on the back of her gloved hand,
she followed immediate protocol for cleanup .
Her hands had been in the gloves a while and the sweat formed an ionic bridge to pass the chemical. its scary out there.
It didn't end well for this "expert".
Nitrile gloves will let stuff through but dimethylmercury is nasty stuff, not stuff you run into routinely
If you think you will be cleaning a lot, double glove
Will nitrile gloves pass carb cleaner or brake cleaner? Acetone?
- 910 Views
- 1792 Views
Last post by landl4u2
- 518 Views
Last post by jimmy57
- 1116 Views
Last post by crisnumbertwo
- 1467 Views
Last post by FLXC90
