Best way to connect my iPhone to my HU-613? Topic is solved
Jonboy74
Year and Model: V70 2.4T, 2002
Has thanked: 119 times
Been thanked: 15 times
Post by Jonboy74 »
So, that pretty much says it.
I'm primarily interested in just playing podcasts from my iPhone while I'm driving.
It would be nice to have hands-free connectivity for calls, but that is not a priority, as Bluetooth headset would be used for calls generally.
I'm not afraid to pull the radio out, and I've got a background in electronics.
Requirements: I'm not interested in lots of gimmicks or anything costly/time consuming. I saw a post about building out some kind of Arduino display to go next to the radio, and while that is TOTALLY COOL, I don't have time or desire to do that at this stage. I'd be happy with an 1/8" stereo plug, but Bluetooth might be interesting if it isn't too costly. (I'm not willing to spend much more than $100 on this endeavor)
Also, I'm wondering if there is a way to show an Aux input on the stereo source menu?
Thanks!
Jonboy
Has thanked: 1500 times
Been thanked: 3812 times
You can solder in a Jack into the tape inputs on the circuit Baord, then stick a blank tape into the tape deck to use the tape function. I use a copy of Marcel Marceau Greatest Soundtracks
I’ll confess I Seldom use the plug now, an FM Bluetooth transmitter is easier
Night night , from Elizabeth
ionianp2
Year and Model: 2004 Volvo s60
Been thanked: 7 times
Post by ionianp2 »
You could also buy a bluetooth kit such as GROM kit or Yatour. They used to be pricey a few years buck. I got mine for about $100 five years ago and it still works great.
These types of kits have a jack that hooks up to the back of the HU-613. It detects it as a cd changer. They also come with a mic, usb charger, and 3.5mm jack for aux.
I also noticed that the steering wheel controls work natively to skip songs or answer calls.
But if you want to do something on the very cheap, an fm bluetooth transmitter is the way to go, but you will have noise depending on the FM bands and you will have to plug it into a 12v
Jonboy74
Post by Jonboy74 »
ionianp2 wrote: 11 Jun 2020, 06:31 You could also buy a bluetooth kit such as GROM kit or Yatour. They used to be pricey a few years buck. I got mine for about $100 five years ago and it still works great.
Ah, I just did a search - this?
https://gromaudio.com/store/all-vol01.html
And if I went with Yatour it looks like I would need two kits if I wanted to include hands-free?
http://www.ycarlink.com/pd_10524_Car-MP ... radios.htm
http://www.ycarlink.com/pd_16665_Yatour ... T-BTM-.htm
ionianp2 wrote: 11 Jun 2020, 06:31 But if you want to do something on the very cheap, an fm bluetooth transmitter is the way to go, but you will have noise depending on the FM bands and you will have to plug it into a 12v
Thought about that - because of the noise/interference potential, I'll probably stay away from that solution.
Thanks!
Jonboy
Jonboy74
Post by Jonboy74 »
abscate wrote: 11 Jun 2020, 04:59 You can solder in a Jack into the tape inputs on the circuit Baord, then stick a blank tape into the tape deck to use the tape function. I use a copy of Marcel Marceau Greatest Soundtracks
LOL, yeah, I suppose I COULD do that....but....Marcel Marceau...HA!
Or I could just do this....
https://www.walmart.com/ip/AmerTac-Zeni ... r/45676862
wait....2002 called, they want their adapter back.... :lol: :lol:
Good night Elizabeth,
Jonboy
ionianp2
Post by ionianp2 »
That is correct. I got the cheaper one that lists for $139. I thought it was a bit of coin back in the day, but the ease of installation and 5 years of having it hassle free, it does the job.
msyverts
Year and Model: 2001 V70 2.4T
Post by msyverts »
I have used the GROM-BT3 unit for years, with the HU-613. It's great for playing podcasts. The mic audio doesn't seem to be great for phone calls, so I use iPhone ear buds for that, unless it's just a conference call where I don't need to say anything.
I really wish the steering wheel buttons could be programmed to activate the -15/+15 second buttons, though.
It makes some soft beeps when it connects up, but basically does the job and was really easy to install. Just have to pull out the unit and plug it into the back.
(I tried an Audiovox unit on my partner's 2003 VW, but it never did work. I ended up getting a CRUX unit for that car that works well.)
