So, that pretty much says it.
I'm primarily interested in just playing podcasts from my iPhone while I'm driving.
It would be nice to have hands-free connectivity for calls, but that is not a priority, as Bluetooth headset would be used for calls generally.
I'm not afraid to pull the radio out, and I've got a background in electronics.
Requirements: I'm not interested in lots of gimmicks or anything costly/time consuming. I saw a post about building out some kind of Arduino display to go next to the radio, and while that is TOTALLY COOL, I don't have time or desire to do that at this stage. I'd be happy with an 1/8" stereo plug, but Bluetooth might be interesting if it isn't too costly. (I'm not willing to spend much more than $100 on this endeavor)
Also, I'm wondering if there is a way to show an Aux input on the stereo source menu?
Thanks!
Jonboy
Best way to connect my iPhone to my HU-613? Topic is solved
You can solder in a Jack into the tape inputs on the circuit Baord, then stick a blank tape into the tape deck to use the tape function. I use a copy of Marcel Marceau Greatest Soundtracks
I’ll confess I Seldom use the plug now, an FM Bluetooth transmitter is easier
Night night , from Elizabeth
ionianp2
- Year and Model: 2004 Volvo s60
- Has thanked: 16 times
- Been thanked: 10 times
You could also buy a bluetooth kit such as GROM kit or Yatour. They used to be pricey a few years buck. I got mine for about $100 five years ago and it still works great.
These types of kits have a jack that hooks up to the back of the HU-613. It detects it as a cd changer. They also come with a mic, usb charger, and 3.5mm jack for aux.
I also noticed that the steering wheel controls work natively to skip songs or answer calls.
But if you want to do something on the very cheap, an fm bluetooth transmitter is the way to go, but you will have noise depending on the FM bands and you will have to plug it into a 12v
Jonboy74
- Year and Model: V70 2.4T, 2002
- Has thanked: 119 times
- Been thanked: 15 times
Ah, I just did a search - this?ionianp2 wrote: 11 Jun 2020, 06:31 You could also buy a bluetooth kit such as GROM kit or Yatour. They used to be pricey a few years buck. I got mine for about $100 five years ago and it still works great.
https://gromaudio.com/store/all-vol01.html
And if I went with Yatour it looks like I would need two kits if I wanted to include hands-free?
http://www.ycarlink.com/pd_10524_Car-MP ... radios.htm
http://www.ycarlink.com/pd_16665_Yatour ... T-BTM-.htm
Thought about that - because of the noise/interference potential, I'll probably stay away from that solution.ionianp2 wrote: 11 Jun 2020, 06:31 But if you want to do something on the very cheap, an fm bluetooth transmitter is the way to go, but you will have noise depending on the FM bands and you will have to plug it into a 12v
Thanks!
Jonboy
Jonboy74
LOL, yeah, I suppose I COULD do that....but....Marcel Marceau...HA!abscate wrote: 11 Jun 2020, 04:59 You can solder in a Jack into the tape inputs on the circuit Baord, then stick a blank tape into the tape deck to use the tape function. I use a copy of Marcel Marceau Greatest Soundtracks
Or I could just do this....
https://www.walmart.com/ip/AmerTac-Zeni ... r/45676862
wait....2002 called, they want their adapter back....
Good night Elizabeth,
Jonboy
ionianp2
That is correct. I got the cheaper one that lists for $139. I thought it was a bit of coin back in the day, but the ease of installation and 5 years of having it hassle free, it does the job.
msyverts
- Year and Model: 2001 V70 2.4T
I have used the GROM-BT3 unit for years, with the HU-613. It's great for playing podcasts. The mic audio doesn't seem to be great for phone calls, so I use iPhone ear buds for that, unless it's just a conference call where I don't need to say anything.
I really wish the steering wheel buttons could be programmed to activate the -15/+15 second buttons, though.
It makes some soft beeps when it connects up, but basically does the job and was really easy to install. Just have to pull out the unit and plug it into the back.
(I tried an Audiovox unit on my partner's 2003 VW, but it never did work. I ended up getting a CRUX unit for that car that works well.)
- 577 Views
Last post by rejaccount
- 3845 Views
Last post by vtl
- 897 Views
Last post by youngin9494
- 631 Views
Last post by GregAivaliotis
- 1276 Views
Last post by GDATL
