engine serial number where is it
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
My sticker has long ago unstuck itself from the timing cover, i want to check i have fitted the correct timing belt and tensioner kit. I cannot find info on VIDA, my registration papers have a engine number but it has too many numbers and letters in it. I looked on the engine block but cannot see anything where VIDA says it should be.
2001 XC70 factory M58
2002 XC70 auto (parts car)
You have to remove the exhaust cover plate and look on a shelf right behind the exhaust cam side of the cylinder head, and clean it with a paper towel and gunk remover
Right “behind” to the left side of the water pipe
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
Its like the crank timing mark, you can't see it with both eyes and only the first 2 numbers are accessible.
And thats if you know exactly where its located and get it cleaned enough to read.
Photo above is probably from a boroscope.
I reached in with my cellphone and took a dozen photos, finally got it after scrubbing the shelf with a toothbrush and brakecleen.
I need to swap the steering rack too, should have just pulled the engine and made everything easier.
- RickHaleParker
- Been thanked: 977 times
Active
Past
Past
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
abscate wrote: 13 Jun 2020, 04:57 You have to remove the exhaust cover plate and look on a shelf right behind the exhaust cam side of the cylinder head, and clean it with a paper towel and gunk remover
I wish mine was looking this good
On P2 cars Volvo hired an old lady to stamp the blocks
- 837 Views
Last post by Ozark Lee
- 1221 Views
Last post by theWaterBiscuit
- 748 Views
- 20 Replies
- 4038 Views
- 545 Views
Last post by UCrazyKid
