29.12 Miles per gallon 2001 xc70 Topic is solved
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
Just did a 1000km trip in my 239k 2001xc70. My trip computer at start of trip said 11litres/100km but is now saying 9.6L/100km i think thats around 29.12 Miles per 1 US gallon (not sure)
Is this good for a 19 year old car?
miles per gallon
miles per gallon
2001 XC70 factory M58
2002 XC70 auto (parts car)
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
What was average road speed during this trip? Mostly highway or city? What engine do you have?
Has thanked: 1611 times
Been thanked: 4072 times
About 25 mpg. Decent for an XC on motorway
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
on a long trip 400 -800 miles I creep up to 28mpg. otherwise 24mpg.
2004 V70 turbo....thats all torn apart right now.
jonesg wrote: 18 Jun 2020, 14:30 on a long trip 400 -800 miles I creep up to 28mpg. otherwise 24mpg.
That’s infinite miles to the gallon according to L’Hospitals Rule
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
There are a driving variables as well as "mechanical" ones that influence quite a bit these numbers
As mentioned above, 120kmh (75mph) vs 90kmh (55mph) gives very different mpg
Tire pressure, wheel geometry, tire size also matter a bit, winds
"Mechanically" speaking, can influence a lot, injectors not having a good spray pattern, faulty O2 sensor, spark plugs, air filter, piston compression, PCV, various sensors..
jonesg
Post by jonesg »
abscate wrote: 18 Jun 2020, 14:40
I'm getting 7 months to the gallon currently.
darrylrobert
No motorway/highway, alot of winding steep climbs and decents. speed from 100km/h max to 80km/h alot of road works. Engine is 2.4T manual, used cruise control on the few straight sections, generally drove like an old man.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
On both our P2 cars (2003 V70 2.4 NA auto and 2005 S80 2.5T auto) I found that the onboard mileage calculator always indicated SLIGHTLY worse MPG than if I calculated actual fuel burned vs actual miles traveled. I also found that I could get better mileage by NOT using CC. CC doesn’t have the ability to look down the road and “anticipate” what power will be needed to climb the next hill and slowly increase the throttle ahead of the hill in order to avoid laboring the engine and causing unnecessary downshifting, etc. Conversely for when you see a downhill coming - you can start letting up on the gas ahead of time.
oragex
Post by oragex »
Steep roads will indeed take a tool on mpg, even if you also go downhill, I think uphill mpg is a lot worse than downhill 'savings'.
Also going from 80 to 100 (60mph) means accelerations, another factor
I feel you are not far from the right numbers at 10l/100km given the conditions for the turbo AWD, I would be have been surprised to see 8l/100km. How is city mpg ?
