I have a 1996 850 turbo and would like the pin setup for OBD1. If anybody has one or information that would help me I would appreciate it.
I am not sure if I have to get an engine wiring harness for a 1995 850t or if I can just get the wiring that has the pins that go on the computer housing.
Want to have OBD1 for 1996 850t Topic is solved
- misha
- Has thanked: 155 times
- Been thanked: 432 times
You can't retrofit OBDI in OBDII car,but you can use flash code reader for ECU and ECC since '96 850 T5 have M4.3 management which still produce flash codes.
All other modules are fully OBDII.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
850
- Year and Model: 1996 850t
I think I can figure out how to pull the flash codes. So I can view flash codes but cannot enter codes to test components like OBDI? I just purchased a Bosch 1350 code reader hoping it would help me view transmission codes, ABS codes, and maybe even allow me to open ABS valves.
Thank you for your response. I guess the way I really want to go is just to buy a 1995 850 T5 if I can find one. I really like the OBDI on these cars as you can do so much with it like open each transmission solenoid, test climate control etc.
- misha
'95 will have both....OBDI under the hood and OBDII at center console.
From '96 there was only OBDII at center console.
No...you can't enter OBDI codes in OBDII car.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 1332 Views
Last post by adventurer2112
- 584 Views
Last post by Ozark Lee
- 584 Views
Last post by wedgeo
- 538 Views
Last post by Evolvo850B
- 1002 Views
Last post by RickHaleParker
