'04 XC Engine Misfiring-Further Updated (Moisture ruled out - possible defective coils, bad MAF) Topic is solved
- Been thanked: 4071 times
I think they usually do. My PEM failure did not
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Idle smoothes out the second I turn off the CEL.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
That’s with a reset of codes with Vida?
Is it idling ok with the MAF disconnected?
- E Showell
Yes. VIDA "clear all" gives me an instantly smooth idle.
MAF. Is brand new. Haven't unplugged the new MAF.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
I'm finding VIDA worse than useless in these circumstances. It really isn't telling me anything.
And it is not at all apparent that you can get a fuel pressure reading out of it. Principal utility seems to be running the battery down.
'95 855 auto (sold)
'95 855 auto (sold)
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
OK. Whenever the idle speed is not controllable the ECM does random cylinder canceling to keep speed lower (prevents startling driver and runaway car allegations when throttle is punched instead of brake...). Lumpy idle and sometimes misfire codes from this FMEM. The air leak code is the ECM saying it can't drive throttle low enough to control idle speed satisfactorily. Look for air leak, hose, etc. Also need to inspect throttle to assure it is not gunked up or possibly something stuck in it. The throttle checks aren't easy but I get a feeling the idle overspeed control is your lumpy idle that goes away with a code clearing.
- E Showell
Throttle body replaced with used unit cleaned to hospital clean room conditions. FMEM?
Idle overspeed control?
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
Utterly defeated here. Alas, I have discover I am at best a paint-by-numbers-wrench, a/k/a mechanic wannabe. I'll do fine if I already know what the problem is, but, as a diagnostician, my wrenching skills leave much to be desired. Off to the local independent shortly.
'95 855 auto (sold)
'95 855 auto (sold)
That’s a tough one. Don’t beat yourself up,you’ve got the logic brain m having seen first hand.
I’m guessing an intake air leak, brake booster, manifold, purge line, pcv, snorkel crack? Have you had the snorkel off?
- 3150 Views
Last post by itsmekirby
- 5977 Views
Last post by chrism
- 2241 Views
Last post by MoVolvos
- 359 Views
Last post by JaredR
- 26 Replies
- 6526 Views
Last post by ChadLee
