Hello everyone!
I have a 98 Volvo V70 XC Chassis#505073
I have a curious problem...
I have recently, within the last few weeks, replaced my alternator, serp Belt, idler pulley and tensioner. The battery was also replaced the same day.
Today, my battery light came on. I tested the battery, and alternator, and both tested good.
I also tested the alternator while loaded (lights on, fan on high)
And that tested good.
A curious quirk though, when I bump the throttle, the light goes away. Then it comes back on after a few seconds. Then after some idleing, the light stays off for good.
Aside from a slight rough idle, everything feels fine.
Any ideas?
Replacement Alternator was a Ultima Alternator from O'Reilly's.
Battery light on. New Alt and Batt.
- RickHaleParker
- Been thanked: 979 times
Check the battery cables and B+ line for corrosion. Grounds are importation too.alpha318 wrote: 22 Jun 2020, 22:03 A curious quirk though, when I bump the throttle, the light goes away. Then it comes back on after a few seconds. Then after some idleing, the light stays off for good.
Active
Past
Past
- Been thanked: 4068 times
Make sure the exciter wire in the back is clean and non oily
If that’s good, it’s alternator Tetris back to O..o...o....o Reilly’s for anew unit
