I recently bought this car, and it started having this issue recently where I step on the gas, and it takes a few seconds to respond .. this is a Manual, non-turbo ...
it has the following new parts so far
New upgraded Bosch 4 nozzle injectors
New NGK wires, plugs, and coil
New Coolant temp sensor
New Fuel pump
New Bosch camshaft sensor
New Bosch TPS sensor
New Bosch MAP sensor
New Bosch O2 sensor
New Fuel Pump Relay
I never run into the issue unless it's been running hot, and there are days I never encounter it at all, what else should I be looking at?
93 850 GLT intermittent sluggish throttle
- 3022 Views
Last post by Fosgate
- 17 Replies
- 4818 Views
Last post by 850corb
- 2821 Views
Last post by FLXC90
- 2408 Views
Last post by Matty Moo
- 12 Replies
- 5503 Views
Last post by alschnertz
