2004 S60R B8444S (V8) conversion (Previously : Exhaust Manifold removal.)
This topic is in the MVS Volvo Repair Database » 2004 S60R -- Yamaha V8 Conversion!
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
I agonize whether to install a cigarette lighter.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Bolted in:
Active
Past
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Exciting! This is where the fun starts.
RickHaleParker
I am using the hard A/C lines from the XC90. The XC90 has two Evaporators. The S60 has only one. I cut off the excess lines figuring I could braze some Aluminum end caps on like I did decades ago. Looked high and low for the end caps. It is like they been vanished from existence. Any alternative ideas or sources for Aluminum end caps?
Small tube is 9.5mm (3/8") Dia. Large tube is 16MM (5/8") Dia.
Active
Past
RickHaleParker
jonesg wrote: 20 Jun 2020, 08:26 I agonize whether to install a cigarette lighter.
Is it like the Paper or Plastic decision ... Electric or Butane?
Active
Past
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
RickHaleParker wrote: 22 Jun 2020, 20:08 I am using the hard A/C lines from the XC90. The XC90 has two Evaporators. The S60 has only one. I cut off the excess lines figuring I could braze some Aluminum end caps on like I did decades ago. Looked high and low for the end caps. It is like they been vanished from existence. Any alternative ideas or sources for Aluminum end caps?
Machine your own end caps from Aluminum bar stock. Easy for anyone with a lathe, even a hobby lathe.
RickHaleParker
volvolugnut wrote: 25 Jun 2020, 13:21 Machine your own end caps from Aluminum bar stock. Easy for anyone with a lathe, even a hobby lathe.
I do not have a lathe not even a hobby lathe.
On the small one I found a socket cap screw that self threaded into the tube. However it is steel. I never brazed aluminum to steel so I do not know if that will work out. Thinking about sealing it with Loctite red. Then see if a can find the right size bolt to do the larger one.
Active
Past
How about this cap from McMaster Carr?
RickHaleParker
volvolugnut wrote: 25 Jun 2020, 17:11 How about this cap from McMaster Carr?
Those are Copper. Copper - Aluminum junctions are highly susceptible to Galvanic corrosion. That green stuff that grows near the soldered joints of Copper water pipes.
Active
Past
RickHaleParker
Options:
  • 1. Roll the dice with Loctite red.
    2. Roll the dice with aluminum brazing on Aluminum- Steel.
    3. Abandon the whole idea.
Active
Past
