2004 S60R B8444S (V8) conversion (Previously : Exhaust Manifold removal.)
2004 S60R -- Yamaha V8 Conversion!
- RickHaleParker
- Been thanked: 980 times
Bolted in:
Active
Past
Past
- Has thanked: 316 times
- Been thanked: 531 times
Exciting! This is where the fun starts.
- RickHaleParker
I am using the hard A/C lines from the XC90. The XC90 has two Evaporators. The S60 has only one. I cut off the excess lines figuring I could braze some Aluminum end caps on like I did decades ago. Looked high and low for the end caps. It is like they been vanished from existence. Any alternative ideas or sources for Aluminum end caps?
Small tube is 9.5mm (3/8") Dia. Large tube is 16MM (5/8") Dia.
Active
Past
Past
- RickHaleParker
Is it like the Paper or Plastic decision ... Electric or Butane?
Active
Past
Past
- Has thanked: 987 times
- Been thanked: 1078 times
Machine your own end caps from Aluminum bar stock. Easy for anyone with a lathe, even a hobby lathe.RickHaleParker wrote: 22 Jun 2020, 20:08 I am using the hard A/C lines from the XC90. The XC90 has two Evaporators. The S60 has only one. I cut off the excess lines figuring I could braze some Aluminum end caps on like I did decades ago. Looked high and low for the end caps. It is like they been vanished from existence. Any alternative ideas or sources for Aluminum end caps?
- RickHaleParker
I do not have a lathe not even a hobby lathe.volvolugnut wrote: 25 Jun 2020, 13:21 Machine your own end caps from Aluminum bar stock. Easy for anyone with a lathe, even a hobby lathe.
On the small one I found a socket cap screw that self threaded into the tube. However it is steel. I never brazed aluminum to steel so I do not know if that will work out. Thinking about sealing it with Loctite red. Then see if a can find the right size bolt to do the larger one.
Active
Past
Past
How about this cap from McMaster Carr?
- RickHaleParker
Those are Copper. Copper - Aluminum junctions are highly susceptible to Galvanic corrosion. That green stuff that grows near the soldered joints of Copper water pipes.
Active
Past
Past
- RickHaleParker
Options:
- 1. Roll the dice with Loctite red.
2. Roll the dice with aluminum brazing on Aluminum- Steel.
3. Abandon the whole idea.
Active
Past
Past
