2004 S60R B8444S (V8) conversion (Previously : Exhaust Manifold removal.)
This topic is in the MVS Volvo Repair Database » 2004 S60R -- Yamaha V8 Conversion!
RickHaleParker
Been thanked: 981 times
Post by RickHaleParker »
yagger wrote: 27 Jun 2020, 14:59 2006 XC90 VIN: YV4CZ852761299806 - best choice I think.
That is the donor for the ECM and TCM. The CEM out if that would is already sync with the ECM. Don't know if I can get the key transponder. Will simplify thing if I can.
Active
Past
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
I can program key.
RickHaleParker
yagger wrote: 27 Jun 2020, 15:54 I can program key.
How about new remotes when I have the encryption keys for the remotes?
I don't have them right now but I know where I can get everything, blade, case, transponder, remote and remote encryption keys for $60.00 a pair.
I have a local locksmith that can cut the blade but cannot do the programing.
Active
Past
RickHaleParker
Got the Air / ECM box all prettied up and it does not fix. Sits too tall. Thinking of modding the box so it hangs over the frame.
Active
Past
yagger
Post by yagger »
RickHaleParker wrote: 27 Jun 2020, 16:03 How about new remotes when I have the encryption keys for the remotes?
Yes, we can program remote too.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
RickHaleParker wrote: 28 Jun 2020, 11:48 Got the Air / ECM box all prettied up and it does not fix.
You could get a hood scoop like this:
RickHaleParker
volvolugnut wrote: 28 Jun 2020, 13:02 You could get a hood scoop like this:
Did the measurements, It is 2" too high. I am pretty sure I can mod the box if I can find plate plastic to weld in place.
Na that is for a longitudinal engine.
If I was going to go the scoop route, let it be something more like this.
Active
Past
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Go Z31 style
You could probably make something fairly easily to make that air box sit lower.
RickHaleParker
bmdubya1198 wrote: 28 Jun 2020, 20:03 You could probably make something fairly easily to make that air box sit lower.
It is 2" too high sitting on the frame. I thought about cutting a notch on the outside so it would drop 2" but it look like I may not have 2" of clearance above the transmission cable.
ECM wiring harness on the engine side is short and does not give much if any option for relocating the ECM. besides the ECM is mounted on top of the Air box to keep it cool. Heat sink fins are in the air flow.
I might be looking at a custom air box, low but spread out. Maybe do it original hot rod style, rummage around the junk yard until I find a low profile that will do the job. Don't want to go with a small filter, to insure the engine does not asphyxiate.
The MAF housing is molded into the box also. The MAF sensor need to be in a air flow with the same cross section.
Active
Past
I doubt you have room to move it, but don't get hung on the air box must orient as it is now. The air would not care if you turned it sideways.
