Welcome to the world's #1 Volvo forum!
Volvo Fixes & Advice since 2001.
New 850. What stuff are a MUST to replace/repair if the maintenance history is unknown?
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 64 times
Been thanked: 62 times
Re: New 850. What stuff are a MUST to replace/repair if the maintenance history is unknown?
Post by Sveedy »
'96 has ODB2. I have been working my way through the repairs and maintenance issues on my '96, and have 0 regrets. I didn't have history on mine either, so I did the following ASAP in this order:
Timing belt/water pump/serpentine belt etc
PCV system
Motor mounts
Plugs /wires
Coolant hoses
Vacuum hoses
Fuel filter
At times it can feel a bit like eating an elephant, but one bite at a time and you'll get there. :)
eightfifty2x0
Year and Model: 1996 850
Has thanked: 9 times
Been thanked: 3 times
Post by eightfifty2x0 »
Sveedy wrote: Sun Jun 28, 2020 9:26 am '96 has ODB2. I have been working my way through the repairs and maintenance issues on my '96, and have 0 regrets. I didn't have history on mine either, so I did the following ASAP in this order:
PCV system
Motor mounts
Plugs /wires
Coolant hoses
Vacuum hoses
Fuel filter
Awesome list and awesome suggestion! Yeah, i agree, it feels like a huge amount of stuff to repair/replace, but it definitely worth it.
Question - how ciritical is to scan the computer for faults with an OBD2 scanner?
Sveedy
Post by Sveedy »
I bought a scanner to read / clear codes. Important tool to have, though I have only needed it twice - so far. Here you can always go to a parts supply store and they can usually scan / clear codes for no charge.
Sveedy
Post by Sveedy »
Honestly you'll find this site ( MVS) to be one of the most valuable tools you could have. Don't think I could have accomplished all I have done without it.
eightfifty2x0
Sveedy wrote: Sun Jun 28, 2020 10:11 am Honestly you'll find this site ( MVS) to be one of the most valuable tools you could have. Don't think I could have accomplished all I have done without it.
Though am new, it seems to be the case
xHeart
Year and Model: 2.0/2.4/3.2
Has thanked: 38 times
Been thanked: 64 times
Post by xHeart »
eightfifty2x0 wrote: Sun Jun 28, 2020 10:21 am
This is a relevant maintenance log viewtopic.php?f=35&t=46831
Golden Retriever | 2014D VIDA DiCE | 2020 V60CC | 2013A XC90 +150mi/241km | 2001 V70XC +200mi/322km
Past: German Shepherd | 1997 Volvo 854 | 1989 Volvo 740 GL | 1979 Volvo 240
eightfifty2x0
xHeart wrote: Mon Jun 29, 2020 11:27 am This is a relevant maintenance log viewtopic.php?f=35&t=46831
How tricky is to replace the timing belt and the water pump? Does it require extra mechanical knowledge? What tool does one need for the job?
Because i asked at a workshop that specializes on Volvos and they said that for a timing belt and water pump change they charge 350€(almost 400 dollars). Is it worth it to take the car there?
xHeart
Post by xHeart »
eightfifty2x0 wrote: Mon Jun 29, 2020 12:59 pm
$400 with parts is a good deal. BUT, you do not want aftermarket parts.
DIY this car else mileage and age will drain your pocketbook. It is best to use OE/OEM parts for critical service, such as AISIN for water pump, INA for pulley and tensioner, and something like Conti for belt. Include serpentine belt and tensioner to0o
This may help some https://www.matthewsvolvosite.com/faile ... ilure.html
eightfifty2x0
xHeart wrote: Mon Jun 29, 2020 2:19 pm
I was thinking getting the timing belt done at the workshop and all else by me.
Btw, you didnt answer on the timing belt change
ZionXIX
Has thanked: 10 times
Been thanked: 54 times
Post by ZionXIX »
Search youtube for "RobertDIY". He has fantastic videos on nearly everything related to 850 volvos as well as timing belt tutorials. Its important to get the timing correct to avoid damage to the engine. Watch the videos and then decide if you're up for it. Most if it can be accomplished with basic socket set but you will need the ability to remove the passenger wheel and you will need a way to release the tension on the serpentine belt. Lots of creative diy methods on here. It took me 2 afternoons to change my water pump, tensioner, timing belt the first time around.
