That is the donor for the ECM and TCM. The CEM out if that would is already sync with the ECM. Don't know if I can get the key transponder. Will simplify thing if I can.
2004 S60R B8444S (V8) conversion (Previously : Exhaust Manifold removal.)
2004 S60R -- Yamaha V8 Conversion!
- RickHaleParker
- Been thanked: 981 times
Active
Past
Past
- RickHaleParker
How about new remotes when I have the encryption keys for the remotes?
I don't have them right now but I know where I can get everything, blade, case, transponder, remote and remote encryption keys for $60.00 a pair.
I have a local locksmith that can cut the blade but cannot do the programing.
Active
Past
Past
- RickHaleParker
Got the Air / ECM box all prettied up and it does not fix. Sits too tall. Thinking of modding the box so it hangs over the frame.
Active
Past
Past
- yagger
- Year and Model: V60 2016
- Has thanked: 6 times
- Been thanked: 39 times
Yes, we can program remote too.RickHaleParker wrote: 27 Jun 2020, 16:03 How about new remotes when I have the encryption keys for the remotes?
Volvo electronic expert
Online Data Transferring Service for Volvo modules
- Has thanked: 987 times
- Been thanked: 1078 times
You could get a hood scoop like this:
- scoop.JPG (12.24 KiB) Viewed 989 times
- RickHaleParker
Did the measurements, It is 2" too high. I am pretty sure I can mod the box if I can find plate plastic to weld in place.
Na that is for a longitudinal engine.
If I was going to go the scoop route, let it be something more like this.
Active
Past
Past
- Has thanked: 317 times
- Been thanked: 531 times
Go Z31 style
You could probably make something fairly easily to make that air box sit lower.
- RickHaleParker
It is 2" too high sitting on the frame. I thought about cutting a notch on the outside so it would drop 2" but it look like I may not have 2" of clearance above the transmission cable.bmdubya1198 wrote: 28 Jun 2020, 20:03 You could probably make something fairly easily to make that air box sit lower.
ECM wiring harness on the engine side is short and does not give much if any option for relocating the ECM. besides the ECM is mounted on top of the Air box to keep it cool. Heat sink fins are in the air flow.
I might be looking at a custom air box, low but spread out. Maybe do it original hot rod style, rummage around the junk yard until I find a low profile that will do the job. Don't want to go with a small filter, to insure the engine does not asphyxiate.
The MAF housing is molded into the box also. The MAF sensor need to be in a air flow with the same cross section.
Active
Past
Past
I doubt you have room to move it, but don't get hung on the air box must orient as it is now. The air would not care if you turned it sideways.
