brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
abscate wrote: 28 Jun 2020, 16:08 That would fit 1035178 it looks like? Early hydraulic tensioner. Also cam timing marks are notches angled in about 45 degrees vsstraight up on th later one.
Engine break is at 1266196
Added some photos.
RickHaleParker wrote: 29 Jun 2020, 03:03
bmdubya1198 wrote: 28 Jun 2020, 19:59 I think the belt PN depends on the tensioner style. If you have a hydraulic tensioner, go ahead and order the older style kit.
It does. When I did my '98 C70 I counted the teeth to make sure they sent the right one. There is a difference in belt length due to the a difference in the position of the tensioners.
Wow. Thanks, all. Very helpful indeed.
Seems like a good idea to count the number of teeth on the TB.
Amazing to see that short-circuit caught in time, too.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Achieved an oil change. Oil filter was kaput. Yes, that's a hole right through the paper element. Had the same thing on the opposite side.
Been thanked: 4065 times
That’s a custom oil flow bypass feature. Improves HP by 4.86%
wizechatmgr
abscate wrote: 01 Jul 2020, 03:52 That’s a custom oil flow bypass feature. Improves HP by 4.86%
Between that, the AWD prop shaft being off and the exhaust open after the CAT, it's likely true. =)
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Wow! What brand filter is that?
stargate476
Year and Model: 2000 volvo s70
Has thanked: 2 times
Post by stargate476 »
so i replaced my rear deck speakers... my god were those old ones shot...after some searching found these on amazon... fit in the factory mounting brackets. https://www.amazon.com/Renegade-RX830-8 ... V5WLC?th=1 they sound pretty good too, tho anything is an upgrade over what was there
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
stargate476 wrote: 01 Jul 2020, 13:56 so i replaced my rear deck speakers... my god were those old ones shot...after some searching found these on amazon... fit in the factory mounting brackets. https://www.amazon.com/Renegade-RX830-8 ... V5WLC?th=1 they sound pretty good too, tho anything is an upgrade over what was there
Nice! I recently upgraded my rear ones too, they were completely shot. I already had a pair of new 6×9s that was initially intended for another car. Had to cut out some material to make them fit though but it was totally worth it.
BMW 540i 2002
S70 Base 2000
subzerocarfanatic
Year and Model: 2000 Volvo C70 HT
Has thanked: 75 times
Been thanked: 10 times
Post by subzerocarfanatic »
omg....lol.
stargate476
kallekula wrote: 01 Jul 2020, 14:16 Nice! I recently upgraded my rear ones too, they were completely shot. I already had a pair of new 6×9s that was initially intended for another car. Had to cut out some material to make them fit though but it was totally worth it.
nice, yea had i not finally found these, my next option was to go with 6x9s and make them fit... they were a snug fit but mounted up perfectly, recently did my front speakers so audio sounds so much better... next project is to upgrade the head unit
Ocelot
Year and Model: 1998, S70
Has thanked: 61 times
Been thanked: 17 times
Post by Ocelot »
So yesterday two buddies of mine and myself went on the adventure of changing the front struts and all of the strut seats, control arms left and right, antirollbar links on both sides, and the antirollbar bushings. The shocks are from Sachs, the springs are from Lesjöfors, the control arms and antirollbarlinks are from Lemförder. That was my attempt to be so muchOE(M) as possible, without the sacrifice of one of my kidneys :P
I didn't had my coffee yet when I started working so this kinda happended. Can you guess what I did wrong? :lol:
Before
Realising I'm an idiot and should drink my coffee BEFORE the job
Attempt #2: That's the way, uhuh uhuh, I like it.
Some in action photos:
After five hours of work (I took it slow because it's been awhile since I worked on struts, pulling them apart, putting them back together, et cetera) I took Freya for a test drive and boy, what a difference! This coming Tuesday she's up for wheelallignment (front AND rear) and then she'll be ready for the upcoming roadtips :D
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
