Did you miss putting the spring into the lower seat?
Here was my blooper of the week....test assembled a brake line with a ratchet wrench...the ratchet part was theblooper
- 44D71D64-C032-425C-9F28-982374B1F974.jpeg (83.83 KiB) Viewed 768 times
- Ocelot
- Year and Model: 1998, S70
- Has thanked: 61 times
- Been thanked: 17 times
Well, I wish it was that. At first glance I thought that the spring was the same on both sides. I took a calculated guess that observation was right, but boy, am I bad at mathabscate wrote: 02 Jul 2020, 04:56 Did you miss putting the spring into the lower seat?
@ your photo: Yeah, that's something that would happen to me also...
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
Recent car
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Not sure. Just put a Bosch in, we'll see what happens.
- Has thanked: 987 times
- Been thanked: 1075 times
That first time was just for practice.Ocelot wrote: 02 Jul 2020, 05:11Well, I wish it was that. At first glance I thought that the spring was the same on both sides. I took a calculated guess that observation was right, but boy, am I bad at mathabscate wrote: 02 Jul 2020, 04:56 Did you miss putting the spring into the lower seat?
Here was my blooper of the week....test assembled a brake line with a ratchet wrench...the ratchet part was theblooperOnce I pulled it apart again, reversed the spring, everything was fine.
@ your photo: Yeah, that's something that would happen to me also...![]()
Looks like the time I made a tube flare without putting the tube fitting on the tube first.abscate wrote: 02 Jul 2020, 04:56
But if you have the flare tool you can fix that. I had to cut the $15 brake hose to recover my $5 wrenchvolvolugnut wrote: 02 Jul 2020, 12:42Looks like the time I made a tube flare without putting the tube fitting on the tube first.abscate wrote: 02 Jul 2020, 04:56
Looks like a financial decision would have been to cut the $5 wrench off the $15 hose.
But that would have meant the hose won.....volvolugnut wrote: 02 Jul 2020, 15:07 Looks like a financial decision would have been to cut the $5 wrench off the $15 hose.
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
Pulled my harmonic balancer, realized the Corteco replacement doesn't actually fit my 99 like the vendor's fitment notes said, put the old one back on. Fun day!
Good lesson to closely inspect old part and new part before taking apart anything.
07 V50 T5 AWD M66 ~146k miles
- Has thanked: 316 times
- Been thanked: 531 times
That's strange. You'd think the Corteco would work fine, I don't think you can even buy a Volvo one anymore. At least not for a reasonable price.
Unfortunately the only options for red blocks now are URO or MTC. Garbage!
