Could be a chassis break?
31104839 Is 1999 2000 only at FCP, BUT volvo we store says it is basically a P2 part
I think your 1999 must have the earlier -1998 part
1275801 harmonicdamper -1998
The index hole looks right in that one.
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
That would make sense that I have the 98 part here since I don't have variable valve timing and other things that people say should be on my 99. The thing is FCP also has the Volvo blue box part (VOL-31104839) which seems to have both centered and offset alignment holes, where the Corteco only had the offset hole. When I called my Volvo parts department they noted that the original part had be replaced by a new one, so it all adds up. Hoping they send the replacement asap. Thanks for the investigation as always!abscate wrote: 03 Jul 2020, 03:44 Could be a chassis break?
07 V50 T5 AWD M66 ~146k miles
Here’s the VVT deep knowledge , deemed 99% accurate
-1998 no VVT solid cams
1999
VVT exhaust on turbo models only
No VVT on NA engines
2000
VVT on exhaust on turbo models
VVT intake in NA models
1999
2000
- smacknab
Ah ok so it's more a factor of having a non turbo for me.abscate wrote: 03 Jul 2020, 08:49 Here’s the VVT deep knowledge , deemed 99% accurate
1999
2000
Side note for swapping a harmonic balancer, does anyone have any tips? Yesterday I was able to pull and reinstall it with just a rental puller without locking the cams, the belt seemed to keep timing fine. Was that a risky move?
- Has thanked: 316 times
- Been thanked: 531 times
Some late 1999 NAs did in fact have VVT. I believe Evan had a '99 with VVT... must not have been Evita? Could be mixing that up with someone else on here.abscate wrote: 03 Jul 2020, 08:49 Here’s the VVT deep knowledge , deemed 99% accurate
1999
2000
Was it exhaust or intake?bmdubya1198 wrote: 03 Jul 2020, 11:36Some late 1999 NAs did in fact have VVT. I believe Evan had a '99 with VVT... must not have been Evita? Could be mixing that up with someone else on here.abscate wrote: 03 Jul 2020, 08:49 Here’s the VVT deep knowledge , deemed 99% accurate
1999
2000
Evita is solid cams on both, 1999 S70
Intake, just like the 2000+ NAs.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Did you run into any issues? Gonna do this exact thing soondbpjr wrote: 03 Jul 2020, 19:09 Changed AC compressor, replaced dryer and expansion valve..... woohoo have cold air 90+ today
Off topic but always meant to ask, is your handle a symbol of your music interests by any chance?
