Has thanked: 1609 times
Been thanked: 4065 times
Could be a chassis break?
31104839 Is 1999 2000 only at FCP, BUT volvo we store says it is basically a P2 part
I think your 1999 must have the earlier -1998 part
1275801 harmonicdamper -1998
The index hole looks right in that one.
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
abscate wrote: 03 Jul 2020, 03:44 Could be a chassis break?
That would make sense that I have the 98 part here since I don't have variable valve timing and other things that people say should be on my 99. The thing is FCP also has the Volvo blue box part (VOL-31104839) which seems to have both centered and offset alignment holes, where the Corteco only had the offset hole. When I called my Volvo parts department they noted that the original part had be replaced by a new one, so it all adds up. Hoping they send the replacement asap. Thanks for the investigation as always!
07 V50 T5 AWD M66 ~146k miles
Here’s the VVT deep knowledge , deemed 99% accurate
-1998 no VVT solid cams
1999
VVT exhaust on turbo models only
No VVT on NA engines
2000
VVT on exhaust on turbo models
VVT intake in NA models
smacknab
Post by smacknab »
abscate wrote: 03 Jul 2020, 08:49 Here’s the VVT deep knowledge , deemed 99% accurate
1999
2000
Ah ok so it's more a factor of having a non turbo for me.
Side note for swapping a harmonic balancer, does anyone have any tips? Yesterday I was able to pull and reinstall it with just a rental puller without locking the cams, the belt seemed to keep timing fine. Was that a risky move?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
1999
2000
Some late 1999 NAs did in fact have VVT. I believe Evan had a '99 with VVT... must not have been Evita? Could be mixing that up with someone else on here.
bmdubya1198 wrote: 03 Jul 2020, 11:36
1999
2000
Was it exhaust or intake?
Evita is solid cams on both, 1999 S70
bmdubya1198
Intake, just like the 2000+ NAs.
dbpjr
Year and Model: 94 850
Post by dbpjr »
Changed AC compressor, replaced dryer and expansion valve..... woohoo have cold air 90+ today
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
dbpjr wrote: 03 Jul 2020, 19:09 Changed AC compressor, replaced dryer and expansion valve..... woohoo have cold air 90+ today
Did you run into any issues? Gonna do this exact thing soon
ZionXIX wrote: 03 Jul 2020, 19:57
Off topic but always meant to ask, is your handle a symbol of your music interests by any chance?
:lol:
