Issue with 96 850R Starting Not Turning Over Topic is solved
wackenhut
Year and Model: 850R 1996
Post by wackenhut »
Okay, I will check it.
wackenhut
Post by wackenhut »
I just initially opened the hood and both posts were somewhat hot. I drove for about 5 minutes and checked the posts again. The positive one seemed to be hotter. In this case, what should I do?
Thank you.
Been thanked: 4071 times
Take off both clamps and get every thing shiny clean with a wire brush
Reconnect, then look for voltage drops between the ends of the wires and the clamps with the car running and lights on, and report back
wackenhut
Post by wackenhut »
The voltmeter reads about 14 volts. I drove it today and it would not start again. Lifted the hood and waited about 5 minutes. Not sure if the lifting of the hood did anything. After about 5 minutes it started again. Very strange and not sure what else could be the problem. the positive lug is not heating up.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
Would it be possible for you to measure the voltage during starting? You can test the battery and the starter terminals. That test might reveal the source of the problem.
wackenhut
Post by wackenhut »
What does the B cable do that runs from the battery to the fuse box? Does this have any purpose in starting the engine? Is there a way to test if the cable is good or bad?
Also, would a fuse cause this? Maybe the number 1 fuse or fuel pump relay?
Thank you.
Has thanked: 2207 times
Been thanked: 1852 times
I know the B+ cable in the 98-00 cars is a known issue and can be dangerous when they get really bad as they can short out. I can't unfortunately picture the 850 version as been way too long to know if it has a similar issue.
As to it's purpose it runs power up to the main fuse box. Having not actually had one fail completely I am not sure if this would cause your problem.
The fact that your issue would appear to be temperature related it would point to electrical wiring on contacts failing which gets worse when hot. This could point to many items, but you have replaced many items so as has been suggested it may be bad earthing/broken/missing earth wires, or bad positive feed wires to the starter.
Has thanked: 311 times
Been thanked: 817 times
For the record, B+ cable problems are basically nonexistent on 850s. Test it with a voltmeter.
I agree must be electrical.
Fuel pump relay - no. This gives a no-start, but the car would crank just fine.
Fuse, no. They are either working (intact) or not.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
I had bad b+ cable from battery to starter.
I had almost 1v voltage drop on it when everything is warmed up under the hood.
Cold test was always ok and without voltage drop.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
The cable from the battery to the starter is not the B+ cable, it's the starter cable. Agreed, basically every 850 the starter cable has gone bad by now or is going.
As posted above the B+ cable runs from battery to fuse box. The B+ is plagued on 99+ P80 cars but basically trouble free on 850s.
