P2 2005 V70 upper driver seat skin repair 39897761
Has thanked: 1611 times
Been thanked: 4075 times
Off came the driver skin fro repair of a split seam- 35 minutes for this. Much easier than p80
Preflight
Don’t disconnect the battery yet If you have power seats
Remove four plastic covers and remove the M10 bolts (14mm hex, all vertical unlike the P80s), drive seat back to access front , forward for rear.
Remove small torn securing plastic switch cover/holder. Then lift at front, snap off tube in rear
Release the Showell pin to undo the seatbelt
Drive seat to forward so base Is just covering the front rails, set the seat back at 90+- 7 degrees
Disconnect negative on battery
Release electrical - it’s a spring loaded small m4 bolt with an 7mm head hex
Leather release
Head rest pops out - no clips to release
No hog rings at base, a plastic snap ring retainer
There about 1/2 as many hOg rings/springs as the P80 cars , work way up front\ doing side and three cross braces
From rear, peel up as front releases, unclip catches on lumbar adjust from metal stays
(tabs with hole in them pick up clips)
Two cross braces with hog rings in rear.
PictureS to follow
Picture gallery
The lumbar knob is a minimal tools removal
Pop the cover with your swissarmy knife or a small Kroner coin
Pop out knob
Pop off trim plate
Okay, here is the seam I need to repair.
Anyone with a thimble with guidance on the right thread to use here?
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
Dental floss is strong, slippery and available.
Used dental floss would match the colour interior too
Good luck unseeing that
Blech!
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
You didn't know I am a Dental Floss Tycoon.
It's nice to know you'l be riding in the Comfort Arena...
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Tip: the lumbar adjustment mechanism on the higher trim seats (the ones with three bottom sections) adjusts more than the one in lower trims (yours). It will put out more lumbar curvature for those like me tall and with lower back problems. Can be easily swapped
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
Braided dacron fishing line, 30 lb test.
I forgot to do a before picture but you can see where my leather seam had split here
I sewed it up using doubled, standard thread, I only made three booboos which I will fix by restiching around them and then cutting the booboos out.
I sewed with the leather turned inside out using the existing holes as a guide
