Volvo 850 vs 70 series dash interchangeable?
jonslave
- Year and Model: 1997 855R
- Has thanked: 12 times
Have got a 97 855R with a gross melty Texas dash. Have a line on a later 70 series dash setup that looks almost new. My question is are they interchangeable? They certainly look very close. Anybody have an idea?
- RickHaleParker
- Been thanked: 979 times
A P80 70 series dash will fit in a 850 but you will need to change the door panels also. The P80 70 series is a face lifted 850.
Active
Past
Past
- Has thanked: 311 times
- Been thanked: 817 times
If you go to the trouble to install another dash, expect to have to beef up the mounts first before you install. They are basically all failing at this point.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Pretty sure the '98-'00 door panels don't fit the 850 doors.RickHaleParker wrote: 09 Jul 2020, 18:18 A P80 70 series dash will fit in a 850 but you will need to change the door panels also. The P80 70 series is a face lifted 850.
And 98-00 doors will fit on an 850 but you don't get full electronics functionality without also swapping over the x70 dash harness into the 850, or doing some careful re-wiring.
- Has thanked: 2857 times
- Been thanked: 1332 times
This sounds like a Monty Python sketch, where your 850 will eventually become a V70, one part at a time, due to a chain of dependencies.
- 1349 Views
Last post by MadeInJapan
- 2732 Views
Last post by 122sPhil
- 2170 Views
Last post by June
- 3082 Views
Last post by skloon
- 30 Replies
- 4847 Views
