B5254t hard cooling hoses
- Has thanked: 1502 times
- Been thanked: 3817 times
Privet, radek
Are these the heater hoses or the radiator hoses ?
- jreed
- Has thanked: 352 times
- Been thanked: 192 times
Based on what I've seen on my '97 855, using OEM Volvo hoses, I would say it's not normal for good radiator hoses to be hard. New OEM hoses are definitely soft and pliable. With age, the hoses sometimes become harder. Sometimes the hoses have a date code stamped or printed on them. You could check to see if your hoses have a code on them. If they are really old, that could explain why they are hard.
radek93
- Year and Model: S70 98
- Has thanked: 2 times
- Been thanked: 3 times
They are hard after heating. Nothing else happens. The fluid does not disappear. Does not throw through the cap. Maybe the cap does not release excess pressure?jreed wrote: ↑10 Jul 2020, 05:47 Based on what I've seen on my '97 855, using OEM Volvo hoses, I would say it's not normal for good radiator hoses to be hard. New OEM hoses are definitely soft and pliable. With age, the hoses sometimes become harder. Sometimes the hoses have a date code stamped or printed on them. You could check to see if your hoses have a code on them. If they are really old, that could explain why they are hard.
Once the car is hot they will be hard from pressure , that is normal!
- befarrer
- Year and Model: 1998 V70 AWD
- Been thanked: 24 times
With a normal functioning rad cap, those hoses will be under 21psi of pressure. 2/3 the pressure that your tires have. I'd be more looking into the other car on why it's not building pressure in the cooling system.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
05 VW Golf TDI
- 62 Replies
- 4416 Views
- 685 Views
Last post by mlarsonatx
