2005 V70 2.5t AWD ticking/rattling Topic is solved
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Sounds to me like it changed pitch when the transmission shifted ... Exhaust leak.
Active
Past
beentrill
Year and Model: 2005 V70 2.5t
Post by beentrill »
It quiets down a lot after warming up. Also don't hear it in reverse.
Definitely gonna have them check driveshaft, axles, Angle gear. I'm really curious to find out where it's coming from.
I looked up what an exhaust leak is, however, the turbo seems to be in decent shape. No weird smells coming from the engine or climate vents
beentrill
Post by beentrill »
Nevermind. Read more into the exhaust leak and it sounds quiet viable
RickHaleParker
beentrill wrote: 10 Jul 2020, 17:09 It quiets down a lot after warming up.
Exhaust manifold heats and expands sealing the leak.
Exhaust manifold gasket or a loose Exhaust manifold bolt.
Active
Past
beentrill
Post by beentrill »
Gotcha. I'll ask my mechanics to look at that too. It's going in on Monday
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
RickHaleParker wrote: 10 Jul 2020, 17:39
The noise is speed-sensitive, not RPM. Something is loose in the drivetrain AFTER transmission.
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
thats your CV outer on its way out.
2001 XC70 factory M58
2002 XC70 auto (parts car)
beentrill
Post by beentrill »
I'll keep you guys posted on what's up
RickHaleParker
vtl wrote: 10 Jul 2020, 20:14 The noise is speed-sensitive, not RPM. Something is loose in the drivetrain AFTER transmission.
If that where the case it would not go away after the engine warmed up.
Active
Past
vtl
Post by vtl »
RickHaleParker wrote: 10 Jul 2020, 21:25 If that where the case it would not go away after the engine warmed up.
Propeller shaft gets pretty heated by exhaust in front.
