abscate wrote: 03 Jul 2020, 03:39 There is some massively thick steel and framemembers in the back corner near the rear door.
It’s going to be a ***grind****to get through those
P80 harvesting left passenger rocker panel
- Has thanked: 316 times
- Been thanked: 531 times
I love the smell of metal cutting in the morning..
It sounds like......Victory..
Methodology
Bosch Corded sawzall with 12 inch Dewalt metal blade. Used one blade
Methodology
Hey, that doesn't look like a Harbor Freight jack stand under there!
There was no way I was going underneath this car while I was cutting frame members. All bets are off when you are cutting support structure to the underbelly.
I cribbed the back axle with lumber, and had jack stands under the rocker, but the first line of defense was no body parts, including feet, ever went under the car during this.
Hey - in your pic, is your pawl lock bar all the down? Mine sit lower than that, and that is important for full pawl engagement.
Im going to try harvest a passenger floor piece from this car, but that will also be from up top, where my biggest danger is a 6 inch fall.
Don't be this guy
Don't be this guy
Wow, now THAT is impressive! Showing off his new Daytona jack too!
I think the pawl was fully engaged, it's probably the angle of the picture. I always make sure, especially when I use those stands. Those are the newer SKU that doesn't have the issue with the pawl engagement. When compared to my other ones that I returned, the difference is night and day. The lever doesn't go down nearly as much on the recalled stands.
Sorry to be the safety nanny. I need you young guys alive to get junkyard parts in the heat...
Hell, I don't mind it! My cousin complains every time I drag him there with me (he's 22... only 6 months older than me, but you'd think he's 62 with how much he complains) but you gotta be quick to get the good stuff! I can't keep pulling M66s alone, too much work.
There is nothing cool about getting hurt working on your car, either short term or long term.
Full face shield
Glasses
Heavy leather gloves
Good shoes
Ear muffs.
Grinders and Sawzall blades can fly stuff off with high velocity
Be safe out there. Here’s some motivation for the visually oriented....
I've been looking for a decent face shield since March. Unfortunately due to the PPE shortages, the only ones I ever find are the flimsy Covid-proof ones. I want a real one that will hold up to a flying grinder wheel!
Always take precautions while using tools like grinders... I've seen/heard too many horror stories of exploding grinder wheels to use one without eye protection.
- Has thanked: 987 times
- Been thanked: 1075 times
Try industrial supply and welding shops for heavy duty face shields. These type of injuries are way too common. One online source with stock on hand.bmdubya1198 wrote: 16 Nov 2020, 08:47 I've been looking for a decent face shield since March. Unfortunately due to the PPE shortages, the only ones I ever find are the flimsy Covid-proof ones. I want a real one that will hold up to a flying grinder wheel!
https://www.mscdirect.com/browse/tn/Saf ... d=12106825
- 1109 Views
Last post by Klausc
- 35 Replies
- 9014 Views
- 2745 Views
Last post by Clemens
- 2275 Views
Last post by GazmorGuri75
- 430 Views
