Hy buddies !
New question :
My car is from February the 28, 1995. On my tachymeter instrument cluster, I have only the regular watch. Which is already cool !
As a normal human, I'm never satisfied, I would like the install the "full package" (clock, watch, next airport for feed kerosene, which CD is playing on my SC 901, where's my wife and kids), and so and so.
Is it possible, I mean, is my car - pre-equiped ? Any idea.
Tanks to the ones that will answer, if answer there is;
Manov
850 Tachymeter Instrument Cluster replacement
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
good question. I'd guess it would work, maybe you don't have the exterior temperature function of the better cluster (if your car came w/o a temp sensor).
The turbo gauge won't work if you have a NA car, that's for sure.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- misha
- Has thanked: 155 times
- Been thanked: 432 times
There is a rumour that board computer needs to be activated at dealer for cars which are not equipped with it originally.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 2209 times
Can't recall on the 850 how the LCD is controlled. It may be via a switch below the cluster like the S/V70.
It is worth checking behind the blank switch covers. In the V/S 70's for example some were not fitted with the Tracs OFF button. But if you have a button you can pull the blank cover and fit the switch. Maybe your car is the same and is already pre-wired.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
You mean the trip computer? The car *should* be pre-wired for it. I know on 2 of our cars that came without it, the plug for the panel switch was behind one of the blank spots on the dash.
There should also be a connection on the back of the instrument cluster (at least there is on the VDO ones) (The small one on the back of this picture)
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 674 times
- Been thanked: 164 times
Thanks to all of You guys, you're amazing !
I have to unscrew the dashboard anyway to replace it. I will make a picture an the test at this time.
Thanks again to all of you.
Manov
Manov
- Chuck W
I *think* the connector for it should be yellow or green. (Whatever the color of the back of the dash switch is)
- 5073 Views
Last post by oragex
- 2652 Views
Last post by durk80
- 4451 Views
Last post by polskamafia mjl
- 2021 Views
Last post by jrob0201
- 729 Views
Last post by camjohns
