Hi all,
With a VIDA scanner will I be able to reset my service light, program remotes? Does anyone have a link for info on just what I could do with this? Here is a eBay link. Would this be the right one?
https://www.ebay.com/itm/VIDA-DICE-2014 ... 4902.l9144
Thanks
VIDA scanner
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
I don't know anything about VIDA, but the service light (the one that literally says "Service") can be reset in my s70 with a trick of holding down the trip odometer reset button and turning the key to position 2 until it starts flashing and then turning the key back and removing it. Or something like that, there is a video and another website has a write up on it in text.
07 V50 T5 AWD M66 ~146k miles
- patcal
- Has thanked: 99 times
- Been thanked: 10 times
Doesn't work on mine. Seems there is a point where they changed. What year is your S70?smacknab wrote: 20 Jul 2020, 12:00 I don't know anything about VIDA, but the service light (the one that literally says "Service") can be reset in my s70 with a trick of holding down the trip odometer reset button and turning the key to position 2 until it starts flashing and then turning the key back and removing it. Or something like that, there is a video and another website has a write up on it in text.
Pat Callaghan Jr.
98 S70 GLT
98 S70 GLT
- smacknab
Ah weird, mine is a 99patcal wrote: 20 Jul 2020, 12:30Doesn't work on mine. Seems there is a point where they changed. What year is your S70?smacknab wrote: 20 Jul 2020, 12:00 I don't know anything about VIDA, but the service light (the one that literally says "Service") can be reset in my s70 with a trick of holding down the trip odometer reset button and turning the key to position 2 until it starts flashing and then turning the key back and removing it. Or something like that, there is a video and another website has a write up on it in text.
- Has thanked: 2215 times
- Been thanked: 1853 times
You need a reset tool for a 98 for the Service light. There used to be cheap tools out there that could do that and the Airbag light on the 98's but I am not sure if the icarsoft will work on a 98. Vida only works on 99- P80 car electronics and software.
The Vol-Fcr and a VW connector cable to your laptop is the way to go. If you post a request for help on that or look at the Forum specific for that there is a lot of info in there.
Neil
Neil
- Has thanked: 312 times
- Been thanked: 818 times
For a 98, to program remotes you must go to the dealer or a shop that has the dealer software.
The best way to reset the service light is to remove the bulb. Foolproof, permanent and trouble-free.
esl_97_850_T5
- Has thanked: 18 times
- Been thanked: 27 times
If you have an Android device, you can use
xiaotec "850 OBD-II" Android app (available on Google Play) for ~$2 + ELM327-compatible Bluetooth tool.
Some ELM327-compatible Bluetooth tools I've used successfully with "850 OBD-II" app:
- ScanTool.net OBDLink LX BT [recommended]
- ScanTool.net OBDLink MX+ [the most useful long term, though the costliest] [most highly recommended] [this is MX+, not MX BT or MX WiFi]
- BAFX Bluetooth [adequate, cheapest of the 3]
Here's a related post with a little more detail:
viewtopic.php?f=1&t=34190&start=70#p548535
esl_97_850_T5
esl_97_850_T5
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
- RickHaleParker
- Been thanked: 981 times
If you do not have a Android device you can use a Android emulator.esl_97_850_T5 wrote: 22 Jul 2020, 18:43 If you have an Android device, you can use
I have used the free Noxplayer with 850 OBD-II it works good. There are both PC and Mac versions of NoxPlayer.
There are a bunch of Android emulators for Linux. I have not tried any of them.
There is good chance any Android emulator will work with 850 OBD-II.
Active
Past
Past
- patcal
I already use Torque Pro with a OBDII bluetooth. Works great for basic system codes, live data. I was just thinking of a more advance scanner. Going to wait for now. Thanks for all the input.
Pat Callaghan Jr.
98 S70 GLT
98 S70 GLT
